Home » Modeling » TMF (Xtext) » [Help me] broken cross-reference error(when the reference target is deleted, an exception will be thrown out)
icon5.gif  [Help me] broken cross-reference error [message #665902] Mon, 18 April 2011 01:17 Go to next message
I use a simple grammar like this,
Model:
(elements += Element ';')*
Element :
Def
| Use
Def :
'def' name = ID
Use :
'use' def = [Def]
and the case is following,
def var;
use var;
It works well.
But when the "def var" is deleted, an exception will be thrown out (the version of xtext i use is: 1.0.0.v201006170321 )
java.lang.ClassCastException: org.xtext.example.mydsl12.myDsl.impl.UseImpl cannot be cast to org.xtext.example.mydsl12.myDsl.Def
at org.xtext.example.mydsl12.myDsl.impl.UseImpl.getDef(UseImpl. java:75)
at org.xtext.example.mydsl12.myDsl.impl.UseImpl.eGet(UseImpl.ja va:119)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1021)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1013)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:409)
at org.eclipse.xtext.EcoreUtil2.resolveCrossReferences(EcoreUti l2.java:485)
at org.eclipse.xtext.EcoreUtil2.resolveAll(EcoreUtil2.java:469)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolvePr oxies(ResourceValidatorImpl.java:122)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate( ResourceValidatorImpl.java:60)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec( ValidationJob.java:76)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec( ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.IStateAccess$AbstractImpl. readOnly(IStateAccess.java:40)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(Xte xtDocument.java:58)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createI ssues(ValidationJob.java:74)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(Val idationJob.java:63)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Re: [Help me] broken cross-reference error [message #665909 is a reply to message #665902] Mon, 18 April 2011 02:13 Go to previous messageGo to next message
Hi Kevin,
please update to Xtext 1.0.2 - this one was fixed some months ago.
Sebastian
Am 18.04.11 07:17, schrieb Kevin Sun:
> Model:
> Element :
> Def | Use ;
> Def :
> 'def' name = ID ;
> Use :
> 'use' def = [Def]
> def var;
> use var;
> It works well.
> tImpl.java:1021)
> tImpl.java:1013)
> l2.java:485)
> xtDocument.java:58)
> idationJob.java:63)
Re: [Help me] broken cross-reference error [message #665912 is a reply to message #665909] Mon, 18 April 2011 02:52 Go to previous message
thanks. I update the xtext, and there is no problem like this. Smile
Previous Topic:Completion proposal truncated strings
Next Topic:Use of unordered group produces unhelpful error messages
Current Time: Sat Jul 19 08:59:42 EDT 2025
Powered by FUDForum. Page generated in 0.06502 seconds
