Home » Eclipse Projects » Virgo » Snaps and virgo 2.1
Snaps and virgo 2.1 [message #665023] Tue, 12 April 2011 17:19 Go to next message
I'm wondering what version of snaps works with virgo 2.1 and where can I get it. I looked at http://www.eclipse.org/virgo/download/ but there is no note about snaps or slices, so I was a bit lost.
I got the latest from git://git.eclipse.org/gitroot/virgo/org.eclipse.virgo.snaps. git, but it doesn't work in virgo 2.1 as far as I can tell. Is there a way to get it working in 2.1 ?
I know it works in 3.0, but I'd rather not do any major changes like this right now.
Thank you.
Jan
Re: Snaps and virgo 2.1 [message #665043 is a reply to message #665023] Tue, 12 April 2011 23:12 Go to previous messageGo to next message
Looks like I solved the problem by getting some old code from the git repo, tagging it on local and building. Now it works under 2.1. However new problems came to surface. I will create a new topic for those.
In case somebody is wondering , the git SHA for the snaps I used is : dafcf0c861e552baf6f11d8a88c2df53bf32ee6d
Thank you.
Jan
Re: Snaps and virgo 2.1 [message #665067 is a reply to message #665043] Wed, 13 April 2011 03:44 Go to previous messageGo to next message
Hmmm. Chris Frost is on vacation until Monday, but I'm a little surprised that you didn't pick SHA 91b182b265ba5432070f388cde04db149d39a162. Did you try that and find a problem?
We should certainly tag the repo at a point which works with Virgo 2.1. Please would you raise a bug so Chris can look at that on his return?
Re: Snaps and virgo 2.1 [message #665169 is a reply to message #665067] Wed, 13 April 2011 10:38 Go to previous messageGo to next message
Glyn,
in 91b182b265ba5432070f388cde04db149d39a162 I see the org.eclipse.virgo.kernel and related upgraded to 2.2.0.M01 in the "build.versions" file, so I decided that would take me over the edge. Am I wrong ? Should that still work on 2.1 ?
Thank you.
Jan
Re: Snaps and virgo 2.1 [message #665172 is a reply to message #665169] Wed, 13 April 2011 10:43 Go to previous messageGo to next message
Of course you are right. I didn't bother to look inside the other commit.
I tagged commit dafcf0c861e552baf6f11d8a88c2df53bf32ee6d as support-for-virgo-2.1.0.RELEASE for posterity.
Thanks for raising this.
Re: Snaps and virgo 2.1 [message #665177 is a reply to message #665067] Wed, 13 April 2011 10:48 Go to previous messageGo to next message
FYI bug report for the GIT tag:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=342725
Re: Snaps and virgo 2.1 [message #665179 is a reply to message #665172] Wed, 13 April 2011 10:50 Go to previous messageGo to next message
That was fast.
I guess you can close that bug report I just created then.
Best Regards, Jan
Re: Snaps and virgo 2.1 [message #665184 is a reply to message #665179] Wed, 13 April 2011 11:00 Go to previous message
Done, but thanks for raising the bug. It may give others searching for the same solution more chance of finding it.
Previous Topic:Apache Tomcat Context Configuration docBase Attribute
Next Topic:How to get remote repositories working
Current Time: Sat Jul 19 17:17:27 EDT 2025
Powered by FUDForum. Page generated in 0.04341 seconds
