IllegalArgumentException: Error, when applying a stereotype [message #664911] |
Tue, 12 April 2011 09:26 |
Hi all,
When I'm trying to apply a UML profile and stereotype to a UML class diag. , the profile is correctly applied to the model, but I got this error for the stereotype.
org.eclipse.m2m.atl.engine.emfvm.VMException: Exception during invocation of operation applyStereotype on org.eclipse.uml2.uml.internal.impl.ClassImpl@18c26d7 (name: CustomerInterface, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)
Caused by: java.lang.IllegalArgumentException: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@ed4b5a (name: variant, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false)at org.eclipse.uml2.uml.internal.operations.ElementOperations.a pplyStereotype(ElementOperations.java:1411)at org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereoty pe(ElementImpl.java:499)
The ATL file:
module transAppProfile2;
create OUT : UML from IN : UML, Pro : UML;
helper def : getStereotype(name : String) : UML!Stereotype =
UML!Stereotype.allInstancesFrom('Pro')->select(p | p.name = name)->first();
rule Model {
from
s : UML!Model
to
t : UML!Model ( name <- s.name)
do {
t.applyProfile(UML!Profile.allInstancesFrom('Pro')->select(p|p.name='ClassProject')- >first()); }
rule Class {
from
s : UML!Class
to
t : UML!Class (name <- s.name)
do {
t.applyStereotype(thisModule.getStereotype('variant'));}
I see in previous messages that this error is not new, but no one stated how it can be solved or why it's raised.
Does anyone know?
Sally
FUDForum. Page generated in 0.03920 seconds
