Home » Eclipse Projects » P2 » Check for Updates vs Install new Software
Check for Updates vs Install new Software [message #664560] Mon, 11 April 2011 03:31 Go to next message
I am learning to integrate p2 update manager in my rcp application. While installing new plugins works well, the check for updates seems to not recognize when on the update site is a plugin with a higher version (for example 1.0.1 where the existing in the app is 1.0.0).
What have I to do that this works?
Thank you!
Re: Check for Updates vs Install new Software [message #664615 is a reply to message #664560] Mon, 11 April 2011 07:45 Go to previous message
On 04/11/2011 03:32 AM, Christian Eugster wrote:
Update works on "top level IUs". If you open Help>About>Installation
Details>Installed Software, Update should be able to see changes at that
level.
It won't change a single plugin by itself that's included in a feature
that's included in a product, since the versions of the product and
feature specify the version of the plugin.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Supported Environments filtering is not working
Next Topic:p2 headless build failing in runDirector with xml plugins included
Current Time: Sat Jul 19 14:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.24533 seconds
