Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [SOLVED] Recover from SWT Error
[SOLVED] Recover from SWT Error [message #664455] Fri, 08 April 2011 20:08 Go to next message
Hello, world!
I have almost completed a desktop application that uses SWT. The main() method has a try...catch to catch any exceptions that make it up that far. The exception is passed to a window indicating that a critical error occurred and that the program must close.
The problem is that if any part of SWT produced the exception (e.g. passing null in the second argument of the Image constructor), the error window itself produces an exception, which is not optimal. To be more specific, it's a "SWTException: Invalid thread access" exception, pointing to the line at which the code access the Display.
This indicates to me that SWT is stuck. I tried getting creating a new Display instead of calling Display.getCurrent()/Display.getDefault(), but no joy. How can this be fixed?
[Updated on: Wed, 13 April 2011 18:19] by Moderator
Re: Recover from SWT Error [message #664556 is a reply to message #664455] Mon, 11 April 2011 02:14 Go to previous messageGo to next message
On 2011-04-09 02:08, Jonah Bron wrote:
> Hello, world!
The above exception indicates that you are trying to use SWT components
without being in the SWT thread. Without seeing any code snippet its
hard to give proper advice, especially your phrase "The exception is
passed to a window" hides more than it says. Do you have created this
window before? Or are you trying to open a new dialog? What shell are
you referring to?
My best guess it that you should open your error dialog within an
asyncExec invocation of a display that is associated to original main
window.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Recover from SWT Error [message #664734 is a reply to message #664455] Mon, 11 April 2011 14:33 Go to previous messageGo to next message
Hey Daniel, thanks for the reply. I tried that, but the program sat there as if stuck. The error window never appears, but the program does not terminate. It appears that it's waiting for the Display object.
Re: Recover from SWT Error [message #664827 is a reply to message #664734] Tue, 12 April 2011 04:28 Go to previous messageGo to next message
You need to provide a minimal snippet, otherwise it's impossible to
argue about program behavior.
- Daniel
Re: Recover from SWT Error [message #664916 is a reply to message #664827] Tue, 12 April 2011 09:34 Go to previous messageGo to next message
Something to try quickly is to use display.syncExec() rather than
display.asyncExec(). If this does not help then yes, a snippet or some
means of reproducing the problem is needed (ideal snippet template:
http://www.eclipse.org/swt/faq.php#whatisasnippet ).
Grant
"Daniel Kr
Re: Recover from SWT Error [message #665025 is a reply to message #664455] Tue, 12 April 2011 18:13 Go to previous message
Alright, apparently the problem was elsewhere. Part of the problem was that I set it to new Display() instead of Display.getDefault() Rolling Eyes . A bit confusing, but it's sorted out now. FYI, I didn't end up needing syncExec or asyncExec.
Thanks everyone.
Previous Topic:Delete / Resize rectangles in a Canvas
Next Topic:SWT large component widget question
Current Time: Sun Jul 20 10:06:00 EDT 2025
Powered by FUDForum. Page generated in 0.03763 seconds
