Home » Modeling » Graphiti » delete with deletion of connections to nested shapes
delete with deletion of connections to nested shapes [message #664307] Fri, 08 April 2011 06:28 Go to next message
Hi all,
the default delete behavior is to remove also connections of the deleted shape.
Are the business objects linked with those connections also deleted?
I also have the situation that my shape has child shapes with connections attached.
I'm treating this with
public void preDelete(IDeleteContext context) {
super.preDelete(context);
if (!(context.getPictogramElement() instanceof ContainerShape))
return;
ContainerShape container = (ContainerShape) context.getPictogramElement();
for (Shape child : container.getChildren()) {
for (Iterator<Anchor> iter = child.getAnchors().iterator(); iter.hasNext();) {
Anchor anchor = iter.next();
for (Iterator<Connection> iterator = Graphiti.getPeService().getAllConnections(anchor).iterator() ; iterator.hasNext();) {
Connection connection = iterator.next();
DeleteContext ctx = new DeleteContext(connection);
ctx.setMultiDeleteInfo(new MultiDeleteInfo(false, false, 1));
IDeleteFeature deleteFeature = getFeatureProvider().getDeleteFeature(ctx);
if (deleteFeature!=null)
deleteFeature.delete(ctx);
I use the MultiDeleteInfo to suppress the user question for each connection.
But MultiDeleteInfo is marked @noinstantiate.
Is there a better way to achieve this?
And do I have to care about the connection decorators?
Henrik
Re: delete with deletion of connections to nested shapes [message #664312 is a reply to message #664307] Fri, 08 April 2011 07:06 Go to previous messageGo to next message
Deleting shapes or connection do not remove any business objects.
Jos
Re: delete with deletion of connections to nested shapes [message #664322 is a reply to message #664312] Fri, 08 April 2011 07:38 Go to previous messageGo to next message
Yes, not in general.
But it does for EObjects, cf.
org.eclipse.graphiti.ui.features.DefaultDeleteFeature.delete BusinessObject(Object)
-Henrik
Am 08.04.2011 13:06, schrieb Jos Warmer:
> Jos
Re: delete with deletion of connections to nested shapes [message #664425 is a reply to message #664322] Fri, 08 April 2011 14:28 Go to previous messageGo to next message
Henrik, you are right. It does for EObjects. We use custom features for deletion and manage removing shapes and connections ourselves.
Jos
Re: delete with deletion of connections to nested shapes [message #667096 is a reply to message #664425] Tue, 26 April 2011 13:19 Go to previous messageGo to next message
Hi Jos (and Henrik),
can you provide an example?
I had a similar problem in :
http://www.eclipse.org/forums/index.php?t=msg&goto=66709 0&S=e545c26285f418ae58b1f7eded5a1b09#msg_667090
Should I extend the class DefaultDeleteFeature with my OWNDefaultDeleteFeature, and override the method preDelete as Henrik did?
Thanks for the help. Much appreciated!
D.
Re: delete with deletion of connections to nested shapes [message #667110 is a reply to message #664307] Tue, 26 April 2011 15:05 Go to previous message
Hi guys, I did it by following (and adapting) Henrik 's solution:
I mainly extended the DefaultDeleteFeature and Override the method preDelete:
public class MyOWNDefaultDeleteFeature extends DefaultDeleteFeature {
return;
for (Iterator<Anchor> iter = container.getAnchors().iterator(); iter.hasNext();) {
For people that are not expert (e.g. myself), remember that you need also to call your MyOwnDefaultDeleteFeature in your FeatureProvider
public IDeleteFeature getDeleteFeature(IDeleteContext context) {
else {
Util.log("BIMFeatureProvider: calling MyOwnDefaultDeleteFeature for "+context,true);
return new MyOwnDefaultDeleteFeature(this);
Maybe, there is a better solution, but at least this seems work for me.
Thanks for your help and support!
D.
[Updated on: Tue, 26 April 2011 15:07] by Moderator
Previous Topic:Iinstallation and Tutorial
Next Topic:Problems in deleting pictogram elements and model elements
Current Time: Sat Jul 19 12:53:35 EDT 2025
Powered by FUDForum. Page generated in 0.04421 seconds
