Home » Eclipse Projects » DTP » DB inside an RCP Application(How to embed a DB inside an RCP Application)
DB inside an RCP Application [message #662557] Thu, 31 March 2011 02:18 Go to next message
I'm planning to create a RCP project which will use a local database; hence when the RCP Application is distributed each user will have a copy of their own database.
For updates I plan to have a centralised database on a server, which the client can send data to and retrieve updates from.
The reason for a local database for each user is the fact the data is fairly static, it allows for disconnected usage and the data for each user lends itself to SQL queries.
The other option I have is to create my own database system inside the RCP application which is written to a local file.
Would you recommend using DTP for Eclipse in this way, and is it in fact possible? Are their any tutorials or examples of embedding a DB in this way?
So the idea would be a user downloads and installs the RCP application. When the RCP application launches it will auto start the DB (installed with the RCP application).
Any suggestions or feedback would be appreciated.
Cheers
Parmy
Re: DB inside an RCP Application [message #663557 is a reply to message #662557] Tue, 05 April 2011 11:52 Go to previous messageGo to next message
Parmy -
What database are you thinking of using? I think the BIRT/ODA folks have done something around starting a local database like this, but I wasn't involved.
Linda - do you know?
--Fitz
Re: DB inside an RCP Application [message #663984 is a reply to message #663557] Thu, 07 April 2011 01:26 Go to previous messageGo to next message
Hi Fitz
Thank you so much for responding to my post.
I'm planning on using the Derby Database that ships with the Java SDK.
Sorry for the delay in responding to you, but I thought I'd give it a go first.
In the end it was actually quite easy.
If it would be useful I'm quite happy to pull together a tutorial which you guys can post.
In the end it was simply a case of:
1 - Adding the derby.jar file to the project
2 - You now have two choices, create a Derby Database and embed in the RCP Project or create one in the code using JDBC.
3 - To access the Database Directory (in other words to provide a URL to the JDBC Connector) use org.eclipse.core.runtime.FileLocator to point to a directory within the RCP Project Bundle.
I've exported the RCP Project and it works a treat.
That's it in a nutshell; but if it helps I'm happy to put a tutorial together.
Once again thanks for getting back to me so quickly.
Best
Parmy
Re: DB inside an RCP Application [message #664235 is a reply to message #663984] Thu, 07 April 2011 19:25 Go to previous messageGo to next message
We would love a tutorial! And we'd be happy to link to it from our Wiki site if you want to post it elsewhere.
But that's awesome that you were able to get it working quickly.
Thanks for letting us know! Smile
--Fitz
Re: DB inside an RCP Application [message #664340 is a reply to message #664235] Fri, 08 April 2011 08:41 Go to previous messageGo to next message
Hey Brian
That would be my pleasure.
Give me a couple of weeks to pull something together; what's the best way for me to get it to you for preview?
Cheers
Parmy
Re: DB inside an RCP Application [message #666521 is a reply to message #664340] Wed, 20 April 2011 12:46 Go to previous message
Just post it on a blog you have access to and we can link to it from the wiki. Doesn't have to be anywhere special, just so long as it's publicly accessible.
If you need me to, I can put it up on my Blogger blog if you don't have a place for it.
--Fitz
Previous Topic:Create jar file of project with derby DB
Next Topic:SQL Server 2008 Support
Current Time: Sat Jul 19 15:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.08241 seconds
