Home » Modeling » M2T (model-to-text transformation) » List or something
List or something [message #664046] Thu, 07 April 2011 05:53 Go to next message
I'd like to write a little java code generator. Therefore my template hsould genearte the "import"s as well. The only issue is, that it might happen, that I generate generate several identical import, as 'm just looping over a list of ERFeferences. Is there any way to define a list or anything like that, where I can put the generated imports to check via contaions(..) if I have already genearted the4 import?
Kind Regards,
klausen
Re: List or something [message #664290 is a reply to message #664046] Fri, 08 April 2011 05:39 Go to previous messageGo to next message
You should mentioned which template language you use.
If it's Xpand you can use contains or even use a set.
The list literal is []
If you want a set its [].toSet()
Sven
Am 4/7/11 11:53 AM, schrieb Klausen:
> Kind Regards,
> klausen
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: List or something [message #664315 is a reply to message #664046] Fri, 08 April 2011 07:20 Go to previous messageGo to next message
I'm using the normal Acceleo Templates. The meta model is ECORE.
Re: List or something [message #664327 is a reply to message #664315] Fri, 08 April 2011 07:56 Go to previous messageGo to next message
If you put your imports in a Set duplicates should be removed
automatically, but this slightly implies that you need two passes; one
to prepare for code generation and another to code generate. If
preparation gets non-trivial, you might consider an M2M to prepare and
then a simpler M2T to generate.
Ed Willink
Re: List or something [message #664356 is a reply to message #664327] Fri, 08 April 2011 10:13 Go to previous messageGo to next message
ok, but how do a put the imports in a set? My curernt code looks like this
[for (e : EClass | p.eContents())]
import [p.name/].I[e.name/];
[/for]
Do I have to use a let clause?
Re: List or something [message #664373 is a reply to message #664356] Fri, 08 April 2011 10:54 Go to previous messageGo to next message
--------------050103090901000905020808
You can use something like this :
[for (e : EClass | p.eContents()->filter(EClass)->asSet())]
import [allClasses.name]
[/for]
Laurent Goubet
Obeo
> [/for]
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050103090901000905020808--
Re: List or something [message #664374 is a reply to message #664356] Fri, 08 April 2011 10:56 Go to previous messageGo to next message
Generically you could try something like
[for (s : String | p->collect(e : EClass | p.name + '.I' +
e.name)->asOrderedSet()->sortedBy(s : String | s))]
import [s/];
[/for]
but your problem seems much simpler with a fixed package prefix try
[for (e : EClass | p.eContents()->asOrderedSet()->sortedBy(name))]
[/for]
Ed Willink
> this
> [/for]
Re: List or something [message #664375 is a reply to message #664373] Fri, 08 April 2011 10:57 Go to previous messageGo to next message
--------------090408030405060108000300
Without the copy/pasting errors, this gives :
[/for]
Laurent Goubet
Obeo
> [/for]
--------------090408030405060108000300--
Re: List or something [message #664380 is a reply to message #664375] Fri, 08 April 2011 11:17 Go to previous messageGo to next message
Thx,
But my eclipse complain about the asSet() call. Which version of Eclispe / Acceleo do I need?
I'm running
Version: Helios Service Release 1
Build id: 20100917-0705
Acceleo SDK : 3.0.1.v201009150438
Klaus
Re: List or something [message #664562 is a reply to message #664046] Mon, 11 April 2011 03:51 Go to previous message
There was a bug with the "filter" operation which returned a Collection and not the same kind of collection as the source of the operation like:
mySet->filter(...) : Set
mySequence->filter(...) : Sequence
myBag->filter(...) : Bag
myOrderedSet>filter(...) : OrderedSet
And since the "asSet()" operation does not exists on "Collection", it didn't compile.
This bug has been fixed, you should update with the Acceleo update site: http://download.eclipse.org/modeling/m2t/acceleo/updates/rel eases/3.0
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Acceleo wiki: http://wiki.eclipse.org/Acceleo
Blogs: http://stephanebegaudeau.tumblr.com & http://sbegaudeau.tumblr.com
[Updated on: Mon, 11 April 2011 03:52] by Moderator
Previous Topic:[Xtext] syntax errors while running the generator workflow
Next Topic:[JET] How to load a java file with a fully qualified name?
Current Time: Sun Jul 20 15:58:05 EDT 2025
Powered by FUDForum. Page generated in 0.05978 seconds
