Problem with dynamic weaving in equinox [message #663774] |
Wed, 06 April 2011 09:15  |
Hey folks!
I am working on a small JPA bundle which should make use of dynamic weaving in order to get lazy loading to work. Unfortunately, I couldn't get it to work and I have no idea what I am doing wrong. Without dynamic weaving everything works fine.
I followed the offical tutorial ( http://wiki.eclipse.org/EclipseLink/Examples/OSGi/Equinox_By te_Code_Weaving), added the required bundles, added support for dynamic weaving in persistence.xml and started equinox with the parameter " -Dosgi.framework.extensions=org.eclipse.persistence.jpa.equi nox.weaving ".
However, when I try to start my weaving test bundle I get the following exception:
[EL Finer]: Thread(Thread[OSGi Console,5,main])--JavaSECMPInitializer - registering transformer for weaving.jpa.
org.osgi.framework.BundleException: Exception in weaving.test.Activator.start() of bundle weaving.test.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:276)
at org.eclipse.osgi.framework.internal.core.FrameworkCommandProvider._start(FrameworkCommandProvider.java:252)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.osgi.framework.internal.core.FrameworkCommandInterpreter.execute(FrameworkCommandInterpreter.java:155)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.docommand(FrameworkConsole.java:156)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.runConsole(FrameworkConsole.java:141)
at org.eclipse.osgi.framework.internal.core.FrameworkConsole.run(FrameworkConsole.java:105)
at java.lang.Thread.run(Thread.java:636)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/persistence/internal/jpa/deployment/osgi/equinox/EquinoxWeaver
at org.eclipse.persistence.internal.jpa.deployment.osgi.equinox.EquinoxInitializer.registerTransformer(EquinoxInitializer.java:97)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.callPredeploy(JPAInitializer.java:107)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.initPersistenceUnits(JPAInitializer.java:309)
at org.eclipse.persistence.internal.jpa.deployment.JPAInitializer.initialize(JPAInitializer.java:262)
at org.eclipse.persistence.jpa.osgi.PersistenceProvider.getInitializer(PersistenceProvider.java:82)
at org.eclipse.persistence.jpa.PersistenceProvider.createEntityManagerFactory(PersistenceProvider.java:71)
at weaving.test.Activator.start(Activator.java:34)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
My installed bundles are:
id State Bundle
0 ACTIVE org.eclipse.osgi_3.6.2.R36x_v20110210
Fragments=1
1 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_2.2.0.v20110202-r8913
Master=0
2 ACTIVE org.eclipse.osgi.services_3.2.100.v20100503
3 ACTIVE org.eclipse.equinox.cm_1.0.200.v20100520
4 ACTIVE org.eclipse.equinox.common_3.6.0.v20100503
5 ACTIVE org.eclipse.update.configurator_3.3.100.v20100512
7 ACTIVE javax.persistence_2.0.3.v201010191057
8 ACTIVE org.eclipse.persistence.antlr_2.2.0.v20110202-r8913
10 ACTIVE org.eclipse.persistence.asm_2.2.0.v20110202-r8913
11 ACTIVE org.eclipse.persistence.jpa_2.2.0.v20110202-r8913
13 ACTIVE org.apache.derby_10.1.2.1_v200803061811
16 ACTIVE org.eclipse.persistence.core_2.2.0.v20110202-r8913
17 RESOLVED org.eclipse.persistence.jpa.equinox_2.2.0.v20110202-r8913
Master=19
19 ACTIVE org.eclipse.persistence.jpa.osgi_2.2.0.v20110202-r8913
Fragments=17
20 RESOLVED weaving.test_1.0.0
My Activator:
Map<String, Object> properties = new HashMap<String, Object>();
properties.put(PersistenceUnitProperties.CLASSLOADER, this.getClass().getClassLoader());
EntityManagerFactory entityManagerFactory = new PersistenceProvider("org.eclipse.persistence.internal.jpa.deployment.osgi.equinox.EquinoxInitializer").createEntityManagerFactory("weaving.jpa", properties);
EntityManager em = entityManagerFactory.createEntityManager();
I couldn't find any bundle which exports the EquinoxWeaver class. Has anyone an idea what is going wrong with my bundle?
Many thanks in advance and best regards!
Andy
FUDForum. Page generated in 0.04225 seconds
