Home » Archived » BIRT » Slow concurrent report generation(Very slow generation of reports in a concurrent environment)
Slow concurrent report generation [message #663379] Mon, 04 April 2011 15:53 Go to next message
I've a web application running in Jboss that have lots of concurrent users. At a given time, lots of reports are generated.
In this scenario, sometimes reports run very slow! They appear to be waiting for something and then continue. I'm using a Servlet (almost equal to the reference servlet) to handle report generation.
Taking a dump of the threads running, I've noticed something strange:
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b uild(ReportQueryBuilder.java:256)
- locked <0x45a228> (a org.eclipse.birt.report.engine.ir.Report)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b uild(ReportQueryBuilder.java:237)
Do you think there's anything related to this? The 'locked' keyword took my attention, but I don't know what could be causing this! Any clues?
thanks a lot in advance, Ricardo
Re: Slow concurrent report generation [message #663648 is a reply to message #663379] Tue, 05 April 2011 22:49 Go to previous messageGo to next message
Ricardo,
Are all tasks being closed? Are you using runandrender task or run task
followed by render task?
Jason
Re: Slow concurrent report generation [message #663730 is a reply to message #663648] Wed, 06 April 2011 07:04 Go to previous messageGo to next message
Hi, Jason,
All tasks are being closed and I'm using runandrender. Should I try run, then render?
thanks in advance!
Re: Slow concurrent report generation [message #663980 is a reply to message #663730] Thu, 07 April 2011 01:03 Go to previous messageGo to next message
Are you using the Graphical query builder in your datasources or the
normal jdbc datasource. I think this error message needs to be logged
as a bugzilla entry. Any chance you could do that?
Jason
On 4/6/2011 7:04 AM, Ricardo Fernandes wrote:
> Hi, Jason,
> then render?
> thanks in advance!
Re: Slow concurrent report generation [message #664423 is a reply to message #663980] Fri, 08 April 2011 14:21 Go to previous messageGo to next message
I'm using the normal jdbc datasource, providing a JNDI url. I'm opening an entry in Bugzilla. thanks!
Re: Slow concurrent report generation [message #664735 is a reply to message #664423] Mon, 11 April 2011 14:42 Go to previous messageGo to next message
Bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=342325
The problem persists. After a while, reports run very slow. I tested through the same database using another instance and they run fine (there are no locks in the DB).
I'm very frustated with that, because I have to restart every day the app. server. After restarting, everything becomes alright. Memory and CPU utilization is OK during that.
thanks in advance!
Re: Slow concurrent report generation [message #664736 is a reply to message #664735] Mon, 11 April 2011 14:45 Go to previous messageGo to next message
Another info: looking at the thread dump, I've noticed there are lots of threads related to birt that are in "Runnable" state.
Re: Slow concurrent report generation [message #664836 is a reply to message #664736] Tue, 12 April 2011 05:09 Go to previous messageGo to next message
Can you post the code you are using? Are you using runandrender task or
separate run and then render task?
Jason
Re: Slow concurrent report generation [message #757826 is a reply to message #664836] Mon, 21 November 2011 14:26 Go to previous messageGo to next message
Ricardo,
Have you solved this problem?
Re: Slow concurrent report generation [message #758104 is a reply to message #757826] Mon, 21 November 2011 16:30 Go to previous messageGo to next message
Gustavo
Are you having this issue?
This looks to me like task where not being closed or the rptdocument not
being closed.
Jason
On 11/21/2011 2:26 PM, Gustavo Lanna wrote:
> Ricardo,
> Thanks
Re: Slow concurrent report generation [message #758826 is a reply to message #758104] Thu, 24 November 2011 11:21 Go to previous messageGo to next message
Jason,
Thank you for reply! I'm using birt runtime WebViewer, and I do not close taks and rptdocuments. There is a way to do this in WebViewer?
Gustavo
Re: Slow concurrent report generation [message #759488 is a reply to message #758826] Mon, 28 November 2011 14:35 Go to previous message
If you are using the WebViwer the documents should be getting closed
automatically.
Jason
On 11/24/2011 11:21 AM, Gustavo Lanna wrote:
> Jason,
> Gustavo
Previous Topic:Integration with Active Directory?
Next Topic:Specifying only the JNDI details for report template?
Current Time: Sun Jul 20 16:42:51 EDT 2025
Powered by FUDForum. Page generated in 0.05685 seconds
