Re: Building a large XSD Schemas with annotations [message #663952 is a reply to message #663944] |
Wed, 06 April 2011 17:52  |
--------------030507090309010305060608
Renat,
Comments below.
Renat Zubairov wrote:
> Hello Ed,
> Thnx for the answer. My comments below:
> Quote:
>> It does indeed do a serious amount of work every time the DOM is
>> changed. There's a listener that wants to update the associated
>> schema components and then a full analysis of the whole schema is
>> triggered...
> Could you please elaborate more on that, I was trying to understand
> what it does, any explanation would be appreciated.
Look in XSDSchemaImpl at this. If you set a breakpoint in the
handleEvent, you'll see it triggers a *huge *cascade of processing.
protected EventListener getEventListener()
if (eventListener == null)
class XSDSchemaEventListener implements EventListener,
Serializable
private static final long serialVersionUID = 1L;
public void handleEvent(Event event)
if (event instanceof MutationEvent)
> Quote:
>> There's currently no ability to just turn off the event listener,
>> which probably would be a reasonable thing to employ in this case,
>> i.e., when DOM changes are known not to significantly impact the
>> schema model. Or perhaps a mode where non-schema namespace attributes
>> changes (other than xmlns ones) would be ignored...
> I can do that. Just need to understand what this listener does, and
> why it takes so much time and resources.
I doubt much can be done without messing deeply with the schema model's
implementation.
> P.S. Nobody uses/generating large XSD schemas with EMF? Strange.
I don't imagine folks change their models so often that a few minutes
for a large schema is a big concern...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Renat,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:inilii$t7u$1@news.eclipse.org" type="cite">Hello
Ed,
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">It does indeed do a serious amount of work
every time the DOM is changed. There's a listener that wants to update
the associated schema components and then a full analysis of the whole
schema is triggered...
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
handleEvent, you'll see it triggers a <b>huge </b>cascade of
processing.<br>
<blockquote><small> protected EventListener getEventListener()</small><br>
<small> {</small><br>
<small> if (eventListener == null)</small><br>
<small> class XSDSchemaEventListener implements EventListener,
Serializable</small><br>
<small> private static final long serialVersionUID = 1L;</small><br>
<br>
<small> public void handleEvent(Event event) </small><br>
<small> if (event instanceof MutationEvent)</small><br>
</blockquote>
<blockquote cite="mid:inilii$t7u$1@news.eclipse.org" type="cite"><br>
<br>
<blockquote type="cite">There's currently no ability to just turn off
the event listener, which probably would be a reasonable thing to
employ in this case, i.e., when DOM changes are known not to
significantly impact the schema model. Or perhaps a mode where
non-schema namespace attributes changes (other than xmlns ones) would
be ignored...
<br>
</blockquote>
<br>
<br>
I can do that. Just need to understand what this listener does, and why
<br>
</blockquote>
implementation.<br>
<br>
</blockquote>
for a large schema is a big concern...<br>
</body>
</html>
--------------030507090309010305060608--
FUDForum. Page generated in 0.04134 seconds
