Home » Modeling » GMF (Graphical Modeling Framework) » Error in generated code: package name used wrongly
Error in generated code: package name used wrongly [message #663838] Wed, 06 April 2011 11:32 Go to next message
The code generated from GMF refers to classes from the metamodel in this way:
<EPackageName>.<EClassName>
i.e. Navigation.Page instead of Page
it try also to import the whole package:
import it.polito.softeng.momaapp.metamodels.Navigation;
while that package contains the actual classes generated for the metamodel (I set the "Base Package" option in the genmodel).
I don't know if the problem is related to the fact that the metamodel refer to another metamodel.
I report the gmfgen file:
<gmfgen:GenEditorGenerator xmi:version="2.0"
    xmlns:gmfgen="http://www.eclipse.org/gmf/2009/GenModel" copyrightText="">
  <diagram
      visualID="1000"
      editPartClassName="ApplicationEditPart"
      itemSemanticEditPolicyClassName="ApplicationItemSemanticEditPolicy"
      canonicalEditPolicyClassName="ApplicationCanonicalEditPolicy"
      iconProviderPriority="Low"
      validationProviderPriority="Low">
    <diagramRunTimeClass
        href="../../../plugin/org.eclipse.gmf.runtime.notation/model/notation.genmodel#//notation/Diagram"/>
    <elementType
        xsi:type="gmfgen:MetamodelType"
        editHelperClassName="ApplicationEditHelper"/>
    <viewmap
        xsi:type="gmfgen:FigureViewmap"
        figureQualifiedClassName="org.eclipse.draw2d.FreeformLayer"/>
    <domainDiagramElement
        href="../../it.polito.softeng.momaapp.metamodels/model/Navigation.genmodel#//Navigation/Application"/>
    <topLevelNodes
        visualID="2001"
        editPartClassName="PageEditPart"
        itemSemanticEditPolicyClassName="PageItemSemanticEditPolicy"
        canonicalEditPolicyClassName="PageCanonicalEditPolicy"
        graphicalNodeEditPolicyClassName="PageGraphicalNodeEditPolicy"
        createCommandClassName="PageCreateCommand">
          href="../../../plugin/org.eclipse.gmf.runtime.notation/model/notation.genmodel#//notation/Node"/>
      <elementType
          editHelperClassName="PageEditHelper"/>
      <viewmap
          xsi:type="gmfgen:InnerClassViewmap"
          className="PageFigure"
          classBody="&#xA;/**&#xA; * @generated&#xA; */&#xA;public class PageFigure extends org.eclipse.draw2d.RoundedRectangle {&#xA;&#xA;&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9; */&#xA;&#x9;private org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel fFigurePageLabelFigure; &#xA;&#xA;&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9; */&#xA;&#x9;public PageFigure() {&#xA;&#x9;&#x9;&#x9;&#x9;this.setCornerDimensions(new org.eclipse.draw2d.geometry.Dimension(getMapMode().DPtoLP(8)&#xA;, getMapMode().DPtoLP(8)&#xA;));&#xA;this.setBorder(new org.eclipse.draw2d.MarginBorder(getMapMode().DPtoLP(5)&#xA;, getMapMode().DPtoLP(5)&#xA;, getMapMode().DPtoLP(5)&#xA;, getMapMode().DPtoLP(5)&#xA;));&#xA;&#x9;&#x9;createContents();&#xA;&#x9;}&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9; */&#xA;&#x9;private void createContents(){&#xA;&#xA;&#xA;fFigurePageLabelFigure = new org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel();&#xA;fFigurePageLabelFigure.setText(&quot;Page&quot;);&#xA;&#xA;this.add(fFigurePageLabelFigure);&#xA;&#xA;&#xA;&#x9;}&#xA;&#xA;&#xA;&#xA;&#xA;&#xA;&#x9;/**&#xA;&#x9; * @generated&#xA;&#x9; */&#xA;&#x9;public org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel getFigurePageLabelFigure() {&#xA;&#x9;&#x9;return fFigurePageLabelFigure;&#xA;&#x9;}&#xA;&#xA;&#xA;}&#xA;&#xA;"/>
      <modelFacet>
        <metaClass
            href="../../it.polito.softeng.momaapp.metamodels/model/Navigation.genmodel#//Navigation/Page"/>
        <containmentMetaFeature
            href="../../it.polito.softeng.momaapp.metamodels/model/Navigation.genmodel#//Navigation/Application/nodes"/>
        <childMetaFeature
      </modelFacet>
      <labels
          visualID="5001"
          editPartClassName="PageTitleEditPart"
          itemSemanticEditPolicyClassName="PageTitleItemSemanticEditPolicy"
          elementIcon="true">
        <viewmap
            xsi:type="gmfgen:ParentAssignedViewmap"
            getterName="getFigurePageLabelFigure"
            figureQualifiedClassName="org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel"/>
        <modelFacet
            xsi:type="gmfgen:FeatureLabelModelFacet"
            parser="//@labelParsers/@implementations.0">
          <metaFeatures
              href="../../it.polito.softeng.momaapp.metamodels/model/Navigation.genmodel#//Navigation/Page/title"/>
        </modelFacet>
      </labels>
    </topLevelNodes>
    <palette>
      <groups
          title="Objects"
          collapse="true">
        <entries
            xsi:type="gmfgen:ToolEntry"
            title="Page"
            description="Create new Page"
            genNodes="//@diagram/@topLevelNodes.0"/>
      </groups>
    </palette>
    <preferencePages
        xsi:type="gmfgen:GenStandardPreferencePage"
        iD="it.polito.softeng.momaapp.metamodels.diagram.general"
        name="Navigation Diagram">
      <children
          iD="it.polito.softeng.momaapp.metamodels.diagram.appearance"
          name="Appearance"
          kind="Appearance"/>
      <children
          iD="it.polito.softeng.momaapp.metamodels.diagram.connections"
          name="Connections"
          kind="Connections"/>
      <children
          iD="it.polito.softeng.momaapp.metamodels.diagram.printing"
          name="Printing"
          kind="Printing"/>
      <children
          iD="it.polito.softeng.momaapp.metamodels.diagram.rulersAndGrid"
          name="Rulers And Grid"
          kind="RulersAndGrid"/>
    </preferencePages>
  </diagram>
  <plugin>
    <requiredPlugins>org.eclipse.draw2d</requiredPlugins>
  </plugin>
  <editor/>
  <navigator>
    <childReferences
        child="//@diagram"/>
    <childReferences
        parent="//@diagram"
        child="//@diagram/@topLevelNodes.0"/>
  </navigator>
  <diagramUpdater/>
  <propertySheet>
    <tabs
        xsi:type="gmfgen:GenStandardPropertyTab"
        iD="appearance"/>
    <tabs
        iD="diagram"/>
    <tabs
        xsi:type="gmfgen:GenCustomPropertyTab"
        iD="domain"
        label="Core">
      <filter
          xsi:type="gmfgen:TypeTabFilter">
        <types>org.eclipse.gmf.runtime.notation.View</types>
        <types>org.eclipse.gef.EditPart</types>
        <generatedTypes>abstractNavigatorItem</generatedTypes>
      </filter>
    </tabs>
  </propertySheet>
  <domainGenModel
      href="../../it.polito.softeng.momaapp.metamodels/model/Navigation.genmodel#/"/>
  <labelParsers
      extensibleViaService="true">
    <implementations
        xsi:type="gmfgen:PredefinedParser"
        uses="//@diagram/@topLevelNodes.0/@labels.0/@modelFacet"/>
  </labelParsers>
  <contextMenus
      context="//@diagram">
    <items
        xsi:type="gmfgen:LoadResourceAction"/>
  </contextMenus>
</gmfgen:GenEditorGenerator>
Re: Error in generated code: package name used wrongly [message #663872 is a reply to message #663838] Wed, 06 April 2011 12:49 Go to previous messageGo to next message
Federico,
Package names shouldn't be upper case. I'm not sure if that causes a
problem, but I'd try changing it to navigation and see if that helps.
> this way:
> xmlns:xmi="http://www.omg.org/XMI"
> copyrightText="">
> <diagram
> visualID="1000"
> itemSemanticEditPolicyClassName="ApplicationItemSemanticEditPolicy "
> canonicalEditPolicyClassName="ApplicationCanonicalEditPolicy "
> href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Diagram "/>
> <elementType
> <viewmap
> figureQualifiedClassName="org.eclipse.draw2d.FreeformLayer"/ >
> href=" ../../it.polito.softeng.momaapp.metamodels/model/Navigation. genmodel#//Navigation/Application "/>
> <topLevelNodes
> visualID="2001"
> itemSemanticEditPolicyClassName="PageItemSemanticEditPolicy "
> graphicalNodeEditPolicyClassName="PageGraphicalNodeEditPolicy "
> href=" ../../../plugin/org.eclipse.gmf.runtime.notation/model/notat ion.genmodel#//notation/Node "/>
> <elementType
> <viewmap
> classBody="
> * @generated
> * @generated
> * @generated
> createContents();
> * @generated
> fFigurePageLabelFigure.setText("Page");
> * @generated
> <modelFacet>
> <metaClass
> href=" ../../it.polito.softeng.momaapp.metamodels/model/Navigation. genmodel#//Navigation/Page "/>
> href=" ../../it.polito.softeng.momaapp.metamodels/model/Navigation. genmodel#//Navigation/Application/nodes "/>
> <childMetaFeature
> </modelFacet>
> <labels
> visualID="5001"
> itemSemanticEditPolicyClassName="PageTitleItemSemanticEditPolicy "
> elementIcon="true">
> <viewmap
> figureQualifiedClassName="org.eclipse.gmf.runtime.draw2d.ui.figures.WrappingLabel "/>
> <modelFacet
> <metaFeatures
> href=" ../../it.polito.softeng.momaapp.metamodels/model/Navigation. genmodel#//Navigation/Page/title "/>
> </modelFacet>
> </labels>
> </topLevelNodes>
> <palette>
> <groups
> title="Objects"
> collapse="true">
> <entries
> title="Page"
> </groups>
> </palette>
> <preferencePages
> <children
> iD="it.polito.softeng.momaapp.metamodels.diagram.appearance "
> name="Appearance"
> kind="Appearance"/>
> <children
> iD="it.polito.softeng.momaapp.metamodels.diagram.connections "
> name="Connections"
> <children
> name="Printing"
> kind="Printing"/>
> <children
> iD="it.polito.softeng.momaapp.metamodels.diagram.rulersAndGrid "
> </preferencePages>
> </diagram>
> <plugin>
> </plugin>
> <editor/>
> <navigator>
> <childReferences
> <childReferences
> parent="//@diagram"
> </navigator>
> <diagramUpdater/>
> <propertySheet>
> <tabs
> iD="appearance"/>
> <tabs
> iD="diagram"/>
> <tabs
> iD="domain"
> label="Core">
> <filter
> </filter>
> </tabs>
> </propertySheet>
> <domainGenModel
> href=" ../../it.polito.softeng.momaapp.metamodels/model/Navigation. genmodel#/ "/>
> <labelParsers
> <implementations
> </labelParsers>
> <contextMenus
> <items
> </contextMenus>
Re: Error in generated code: package name used wrongly [message #663880 is a reply to message #663838] Wed, 06 April 2011 13:10 Go to previous message
I am out of the office now but that could work. If played a little bit with the GMF Templates: it seems that it calculates correctly the full name and later something trying to produce the import and replace the fully qualified name with the simple name. Maybe it assumes that the class name starts with the first capital letter...
Previous Topic:[ERROR] Cannot modify resource set without a write transaction
Next Topic:Losing relations arcs
Current Time: Sun Jul 20 02:43:44 EDT 2025
Powered by FUDForum. Page generated in 0.04366 seconds
