[EEF] Master detail form extension [message #655092] |
Fri, 18 February 2011 05:04  |
I am using the master detail form generated by EEF. I would like to make some extensions to the toolbar in master part.
Currently, the add button does the following in org.eclipse.emf.eef.runtime.ui.widgets.masterdetails.tree.EE FTreeMasterPart:
menuItem.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
EList<EObject> list = (EList<EObject>) modelRoot.eGet(commandParameter.getReference());
EObject value = EcoreUtil.create(commandParameter.geteClass());
if(editingDomain != null) {
Command command = AddCommand.create(editingDomain, modelRoot,null,value);
editingDomain.getCommandStack().execute(command);
try {
modelRoot.eResource().save(Collections.EMPTY_MAP);
} catch (IOException e1) {
e1.printStackTrace();
It creates an instance of the selected model object and adds it to the model (interestingly, it also saves the model at this point). Instead of this, I would like to bring up the corresponding WizardDialog for the model object so that the user can fill in the required attributes in the wizard itself instead of an empty object getting added (as of now).
Could you give some pointers on how this could be done?
Thanks in advance,
Nirmal
Re: [EEF] Master detail form extension [message #663569 is a reply to message #655092] |
Tue, 05 April 2011 12:38  |
Hello Nirmal, sorry for the delay,
Le 18/02/2011 11:04, Nirmal Sasidharan a écrit :
> Hello,
> FTreeMasterPart:
> @Override
> try {
Sorry, there isn't a 'simple' way to do that in EEF for the moment. The
only thing you can do is to create your own page with your own MasterPart.
> Thanks in advance,
Goulwen
> Regards,
> Nirmal
FUDForum. Page generated in 0.03631 seconds
