oprofile: hangs on Parsing OProfile Data [message #662778] |
Thu, 31 March 2011 17:59  |
Trying to use the OProfile plugin with Eclipse 3.6.2 on Archlinux x86_64. As far as I can tell, OProfile works from the command line.
The plugin itself sometimes seems to work when I run my application with no inputs in which case it just prints out its usage statement and then exits. Sometimes the OProfile tab doesn't come up at all, but sometimes it comes up saying either that no samples were found or it shows one sample in some random function. This seems to make sense as it doesn't take very long for the program to print out its usage statement.
However, profiling any more substantial a run (e.g. still < 1 second) leads to a progress dialog popping up after it has finished which says "Parsing OProfile Data". It doesn't seem to be using any CPU or accessing the harddrive, and it stays at 0% with the Cancel button grayed-out indefinitely.
Any ideas?
FUDForum. Page generated in 0.34227 seconds
