Legal question about SWT [message #663337] |
Mon, 04 April 2011 12:56  |
If I realize a software that uses SWT and Java library, then I compile it with gcj into an exe and distribute it without the sources... is this legal?
[Updated on: Mon, 04 April 2011 12:59] by Moderator
Re: Legal question about SWT [message #666020 is a reply to message #665772] |
Mon, 18 April 2011 12:18   |
The EPL and MPL licenses in SWT/Eclipse are not viral, they apply solely to
the SWT/Eclipse components being used. They only stipulate that you must
provide some source if you make any modifications to the SWT/Eclipse source,
in which case the changes must be made available by some means (eg.- a file
accompanying your app, a link to a site, etc.). However you can license
your own app any way you want, and as a consumer or Eclipse/SWT are not
required to provide any EPL or MPL license texts.
The only remaining piece is gcj, you'll need to look into its terms
separately (eg.- does it say that the end product of a compile is
automatically assigned license XYZ, etc.).
Grant
<dj_def@webmail.it> wrote in message news:ioa8bd$t98$1@news.eclipse.org...
> I'm blocked... Can I or not?
> Inside the about.html in the swt distribution it's written that there are
> pieces with the mpl license, and the mpl license implies that I have to
> distribute the source code too.
> What's the sense of releasing a library under epl and then put inside of
> it all this things with other licenses?
> I didn't know that doing a simple thing like a simple software takes to
> all these troubles.
> Nothing is clear, all is confused :(
FUDForum. Page generated in 0.47526 seconds
