Home » Eclipse Projects » Eclipse Platform » Prevent a view from releasing
Prevent a view from releasing [message #661129] Wed, 23 March 2011 06:11 Go to next message
How could I customize the release view operation (currently put under
perspective.viewfactory.releaseview()) such that do NOT release a
particular view even there is no more reference?
Re: Prevent a view from releasing [message #661917 is a reply to message #661129] Mon, 28 March 2011 10:13 Go to previous messageGo to next message
you can't change that, when there are no more references the view will
be destroyed. The best you can do is save some state in your plugin
somewhere so that if the user re-creates the view you can get back to a
"good" state.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Prevent a view from releasing [message #662538 is a reply to message #661917] Wed, 30 March 2011 22:52 Go to previous messageGo to next message
Already did. My goal is to shorten the view-recreation time.
As long as the view is not disposed (e.g. opened in another
perspective), opening it is instant.
It the view is hidden from all perspective (and disposed), opening shows
a noticable lag-time (no measurement, I should say 0.5~1s).
Any help?
Hei
> "good" state.
> PW
Re: Prevent a view from releasing [message #662640 is a reply to message #662538] Thu, 31 March 2011 07:32 Go to previous message
The framework won't help you with that. 2 suggestions:
1) save as much data as you can so you can re-create quickly and 2)
don't do things like re-connect or complex loading in the UI thread i.e.
createPartControl(*).
If re-creating your data is going to take a long time, create your
SWT/JFace controls in createPartControl(*) and start a
org.eclipse.core.runtime.jobs.Job to recreate your data ... when the Job
is ready, update your view.
PW
Paul Webster
Previous Topic:How can I use IProject.getName() in plugin.xml or plugin.properties file
Next Topic:Problem with RCP on HPUX(PA-RISC)
Current Time: Sun Jul 20 16:47:18 EDT 2025
Powered by FUDForum. Page generated in 0.06368 seconds
