Home » Eclipse Projects » Plugin Development Environment (PDE) » Simple Plugin - Know the path of a file
Simple Plugin - Know the path of a file [message #660550] Sat, 19 March 2011 05:02 Go to next message
Hello!!!
I'm new with Eclipse plugin development !!!
I'm studying this tutorial : http:// www.vogella.de/articles/EclipsePlugIn/article.html#contribut e , but I'd like to create a plugin so when I right-click on a file (for example an html file) and choose for example the Option "Modify HTML" (that I've created), I can open and modify that file.
I think I need only to know the path of the file that I right-click, and so I can open and modify that file using other java-classes.
The code used in this tutorial is :
public class Convert extends AbstractHandler {
	private QualifiedName path = new QualifiedName("html", "path");
	public Object execute(ExecutionEvent event) throws ExecutionException {
		IStructuredSelection selection = (IStructuredSelection) HandlerUtil
				.getActiveMenuSelection(event);
		DirectoryDialog fileDialog = new DirectoryDialog(HandlerUtil
				.getActiveShell(event));
		String directory = "";
		Object firstElement = selection.getFirstElement();
		if (firstElement instanceof ICompilationUnit) {
			ICompilationUnit cu = (ICompilationUnit) firstElement;
			IResource res = cu.getResource();
			boolean newDirectory = true;
			directory = getPersistentProperty(res, path);
			if (directory != null && directory.length() > 0) {
				newDirectory = !(MessageDialog.openQuestion(HandlerUtil
						.getActiveShell(event), "Question",
						"Use the previous output directory?"));
			if (newDirectory) {
				directory = fileDialog.open();
				analyze(cu);
				setPersistentProperty(res, path, directory);
				write(directory, cu);
		} else {
			MessageDialog.openInformation(HandlerUtil.getActiveShell(event),
					"Information", "Please select a Java source file");
		// iterator.next();
		return null;
	protected String getPersistentProperty(IResource res, QualifiedName qn) {
		try {
			return (String) res.getPersistentProperty(qn);
		} catch (CoreException e) {
			return "";
	// TODO: Include this in the HTML output
	private void analyze(ICompilationUnit cu) {
		// Cool JDT allows you to analyze the code easily
		// I don't see really a use case here but I just wanted to do this here
		// as I consider this as cool and
		// what to have a place where I can store the data
		try {
			IType type = null;
			IType[] allTypes;
			allTypes = cu.getAllTypes();
			 * Search the public class
			for (int t = 0; t < allTypes.length; t++) {
				if (Flags.isPublic((allTypes[t].getFlags()))) {
					type = allTypes[t];
					break;
			String classname = type.getFullyQualifiedName();
			IMethod[] methods = type.getMethods();
		} catch (JavaModelException e) {
			e.printStackTrace();
	protected void setPersistentProperty(IResource res, QualifiedName qn,
			String value) {
		try {
			res.setPersistentProperty(qn, value);
	private void write(String dir, ICompilationUnit cu) {
		try {
			cu.getCorrespondingResource().getName();
			String test = cu.getCorrespondingResource().getName();
			// Need
			String[] name = test.split("\\.");
			System.out.println(test);
			System.out.println(name.length);
			String htmlFile = dir + "\\" + name[0] + ".html";
			System.out.println(htmlFile);
			FileWriter output = new FileWriter(htmlFile);
			BufferedWriter writer = new BufferedWriter(output);
			writer.write("<html>");
			writer.write("<head>");
			writer.write("</head>");
			writer.write("<body>");
			writer.write("<pre>");
			writer.write(cu.getSource());
			writer.write("</pre>");
			writer.write("</body>");
			writer.write("</html>");
			writer.flush();
		} catch (IOException e) {
The example given in the tutorial is similar, but with that code I can only open java files.
I think the problem is ICompilationUnit that represents an entire Java compilation unit, but I hadn't understood how I can modify that code to re-use it.
Who can help me ????
Thanks.
[Updated on: Sun, 20 March 2011 07:54] by Moderator
Re: Simple Plugin - Know the path of a file [message #660697 is a reply to message #660550] Mon, 21 March 2011 05:19 Go to previous messageGo to next message
Probably I don't need the path of that file, but I need each code-line of the HTML page that I select (right-click on a file in the Package Explorer and choose for example the option "Modify" I've created).
Does anyone know how can I write this plug-in ???
Which classes should I use to read that file ?
Thank you very much !!!
Re: Simple Plugin - Know the path of a file [message #660808 is a reply to message #660550] Mon, 21 March 2011 12:52 Go to previous messageGo to next message
I've partially resolved.
			IPath url;
			IResource risorsa= cu.getResource();
			url=risorsa.getRawLocation();
			System.out.println("l'url del file selezionato è : "+ url);
			File file=new File(url.toString());
try{
	            InputStreamReader reader = new InputStreamReader (System.in);
	            String str= url.toString();
	            FileInputStream fstream = new FileInputStream(str);
	            DataInputStream in = new DataInputStream(fstream);
	            BufferedReader br = new BufferedReader(new InputStreamReader(in));
	            String strLine;
	            int i=1;
	            while ((strLine = br.readLine()) != null){
	                System.out.println (i+" " + strLine);
	                i++;
	            in.close();
	        }catch (Exception e){
	            System.err.println("Errore: " + e.getMessage());
		return null;
But it reads only java files. I need to read html files.
I think the problem is ICompilationUnit.
How can I resolve it ???
Thanks.
Re: Simple Plugin - Know the path of a file [message #661876 is a reply to message #660550] Mon, 28 March 2011 07:24 Go to previous messageGo to next message
On 03/19/2011 05:03 AM, giancarlo.capone@yahoo.com wrote:
> Hello!!!
> http://www.vogella.de/articles/EclipsePlugIn/article.html#co ntribute ,
> (that I've created), I can open and modify that file. I think I need
You always deal with IFiles for files within a workspace. In the
example, because they knew it was an ICompilationUnit they could get the
resource:
The other way is to adapt to the resource, using the adapter manager:
org.eclipse.core.runtime.Platform.getAdapterManager().getAda pter(firstElement,
IFile.class);
If you want to *write* your output in the same directory ... don't use
that example, that's not what it is doing. Use the IFile to get the
parent directory, and then create a new IFile and write to that.
Later,
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Simple Plugin - Know the path of a file [message #661902 is a reply to message #661876] Mon, 28 March 2011 09:33 Go to previous messageGo to next message
Dear Paul,
I've used the following code (It's only an example... I have only found a way to read each line of the html file and show it in output) :
		System.out.println("Object first element vale : "+firstElement.toString());
		if (firstElement instanceof Object) {
			System.out.println("Sono nel ciclo if ");
			IFile risorsa=(IFile) firstElement;
			System.out.println("risorsa vale : "+risorsa.toString());
			IPath url;
			System.out.println("Il nome del file è "+file.getName()+"\n");
			try{
					String strLine;
					int i=1;
							i++;
					}// fine while
					in.close();
	        } catch (Exception e){
	        }// fine catch
It works fine !!!
Thank you very much !!!!
Re: Simple Plugin - Know the path of a file [message #661932 is a reply to message #661902] Mon, 28 March 2011 10:35 Go to previous messageGo to next message
On 03/28/2011 09:33 AM, Giancarlo wrote:
> Dear Paul,
Unfortunately, that's a bad idea.
That's a blind cast ... verboten. But this might just be your example.
You have to at least check instanceof, and if you expect to work with
the Package Explorer, you need to adapt that object to IResource/IFile.
Casting won't work reliably in the Package Explorer case, and would
case a ClassCastException if you tried this on a java file.
You already have an IFile ... use the getContents() method to get the
original input stream, instead of trying to find the absolute path just
to run it through an InputStream.
Later,
PW
Paul Webster
Re: Simple Plugin - Know the path of a file [message #662927 is a reply to message #661932] Fri, 01 April 2011 10:00 Go to previous messageGo to next message
Dear Paul,
I've modified the code following your suggestions. I hope now it's better.
I expect to work with the Package Explorer.
How can I make it works also with java files or other files ??? In witch way can I understand witch kind of file is it ? (Java file, Html file, ...)
		IFile risorsa = (IFile) selection.getFirstElement();
		System.out.println("IFile risorsa vale : "+risorsa.toString());
		if (risorsa instanceof IResource) {
			int input=0;
                        int i=1;
			boolean finefile= false;
			try {
				InputStream is=risorsa.getContents();
				InputStreamReader isr= new InputStreamReader(is);
				BufferedReader d = new BufferedReader(isr);
				while(!finefile) // finchè non si è raggiunta la fine del file
						try {
								input = d.read();
								if (input == -1) // si è alla fine del file
									finefile = true;
								else{
									try {
										System.out.println(i+"-> "+d.readLine());
										i++;
								} // fine else
				} // fine while
				try {
					d.close();
			} catch (CoreException e1) {
				e1.printStackTrace();
		} // fine if
	return null;
	} // fine metodo execute
	} // fine class Convert
Re: Simple Plugin - Know the path of a file [message #663228 is a reply to message #662927] Mon, 04 April 2011 08:09 Go to previous messageGo to next message
That's a blind cast:
Object obj = selection.getFirstElement();
IFile file = null;
if (obj instanceof IFile) {
file = (IFile) obj;
} else if (obj instanceof IAdaptable) {
file = (IFile) ((IAdaptable)obj).getAdapter(IFile.class);
if (file == null) {
file = (IFile) Platform.getAdapterManager()
.getAdapter(obj, IFile.class);
if (file!=null) {
// do whatever
PW
Paul Webster
Re: Simple Plugin - Know the path of a file [message #668085 is a reply to message #660550] Tue, 03 May 2011 12:55 Go to previous message
I tried to follow vogella guides, but it don't run... and i haven't error... probabilly i did wrong something...
Can you send me source code of this sample project?
Previous Topic:External launch on different thread
Next Topic:How can I call save method in eclipse plugin development programticaly
Current Time: Sun Jul 20 05:49:16 EDT 2025
Powered by FUDForum. Page generated in 1.25680 seconds
