Home » Eclipse Projects » Virgo » Spring context visibility between modules(Spring DM 1.2)
Spring context visibility between modules [message #660981] Tue, 22 March 2011 10:49 Go to next message
I am using Spring DM 1.2(Virgo) and it works great so far but i am having a design issue.
Imagine two bundles, bundleA and BundleB.
Object ConsumerA from BundleA uses an object ProducerB from BundleB.
Now ProducerB encapsulates a bean BeanC injected from the spring context via @Autowired annotation. BeanC is created with information from a property file.
Now, when ConsumerA calls ProducerB, BeanC is not in its scope. A beanNotfoundException is thrown.
I did make it work by referencing BeanC as a service in the service registry but it is not what i want in the end because it is too tight coupled.
Do you have any idea about it? Maybe to redesign how i am doing it?
For more info, my producerB is a Hibernate constraint validator. ConsumerA is JSF2 BeanValidator.
Thanks !!!
[Updated on: Tue, 22 March 2011 10:50] by Moderator
Re: Spring context visibility between modules [message #661030 is a reply to message #660981] Tue, 22 March 2011 15:34 Go to previous messageGo to next message
Reply to myself, we are working on a factory. Will come back as soon as we get something conclusive.
Re: Spring context visibility between modules [message #661405 is a reply to message #660981] Thu, 24 March 2011 10:45 Go to previous messageGo to next message
With SpringDM each bundle has its own individual appContext. There is no sharing of contexts between bundles.
If you need to share types, use Import-Package/Import-Bundle etc.
If you need to share "beans" - use services.
Assuming:
1. A depends on B. (i.e. A has an Import-Package: b)
2. Both A and B need to create Spring application context.
In B set-up an app context with beans ProducerB and BeanC. Inject BeanC into ProducerB. Publish ProducerB as a service.
<osgi:service internface="ProducerBInterface" ref="producerB"/>
In A, import ProducerB as a service
<osgi:reference id="producerB" interface="producerBInterface"/>
Inject "producerB" bean into ConsumerA and use it.
Dmitry
Re: Spring context visibility between modules [message #661485 is a reply to message #661405] Thu, 24 March 2011 17:46 Go to previous message
Edit.
Thanks i wll try that.
[Updated on: Fri, 25 March 2011 06:52] by Moderator
Previous Topic:how to partition system to build bundle?
Next Topic:Current Status of Virgo Tooling
Current Time: Sat Jul 19 10:51:19 EDT 2025
Powered by FUDForum. Page generated in 1.07350 seconds
