Double sided printing of multiple reports? [message #661364] |
Thu, 24 March 2011 07:47  |
I wonder if there's is a way to guarantee a correct double sided printing of multiple reports?
I use BIRT 2.6.2 to generate several reports, which I concatinate into one big pdf printout. When printing the pdf I would like to have double sided printouts, BUT keep the different reports separate, so that each report starts on an new paper instead of the backside of the previous.
I was thinking about checking the pagenumber on each report and insert a blank page if a report ends on an uneven number.
Anyone know if this works? Or is there another way to do this?
Tnx in advance!
Re: Double sided printing of multiple reports? [message #668097 is a reply to message #668069] |
Tue, 03 May 2011 13:47   |
Are you calling the iText libraries directly? Maybe the
PdfCopyFields.addDocument will work. I have an RE API example that
combines to report outputs. I am attaching it.
Jason
package REAPI;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.io.OutputStream;
import com.lowagie.text.pdf.PdfAction;
import com.lowagie.text.pdf.PdfReader;
import com.lowagie.text.pdf.PdfWriter;
import com.lowagie.text.pdf.PdfCopyFields;
import com.lowagie.text.Document;
import com.lowagie.text.Paragraph;
public class CombineReportsPDF {
public void concat(byte[] ba1, byte[] ba2, String outpath){
try{
//Document document = new Document();
//ByteArrayOutputStream baos = new ByteArrayOutputStream();
//PdfWriter writer = PdfWriter.getInstance(document, baos);
//PdfAction pdfAction = new PdfAction(PdfAction.PRINTDIALOG);
//writer.setOpenAction(pdfAction);
//document.open();
//writer.addJavaScript(
// "this.print({bUI: true,bSilent: false,bShrinkToFit: true});" +
//"\r\n" +
//"this.closeDoc();"
//document.add(new Paragraph("What is this doing"));
//PdfReader js1 = new PdfReader(baos.toByteArray());
PdfReader rd1 = new PdfReader( ba1 );
PdfReader rd2 = new PdfReader( ba2 );
PdfCopyFields cpy = new PdfCopyFields( new FileOutputStream( outpath ));
//cpy.addDocument(js1);
cpy.addDocument(rd1);
cpy.addDocument(rd2);
//cpy.addJavaScript( "this.print({bUI: true,bSilent:
// "\r\n" +
// "this.closeDoc();"
//document.close();
cpy.close();
}catch(Exception e){
e.printStackTrace();
public void runReport() throws EngineException
IReportEngine engine=null;
EngineConfig config = null;
try{
config = new EngineConfig( );
config.setBIRTHome(" C:\\birt\\birt-runtime-2_6_1\\birt-runtime-2_6_1\\ReportEngi ne ");
config.setLogConfig(null, Level.OFF);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
}catch( Exception ex){
ex.printStackTrace();
IReportRunnable design, design2 = null;
//Open the report design
design = engine.openReportDesign("Reports/TopNPercent.rptdesign");
design2 =
engine.openReportDesign("Reports/TopSellingProducts.rptdesign ");
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.setParameterValue("Top Percentage", (new Integer(3)));
task.setParameterValue("Top Count", (new Integer(5)));
task.validateParameters();
PDFRenderOption options = new PDFRenderOption();
ByteArrayOutputStream fso= new ByteArrayOutputStream();
ByteArrayOutputStream fso2= new ByteArrayOutputStream();
options.setOutputStream(fso);
options.setOutputFormat("pdf");
task.setRenderOption(options);
task.run();
task.close();
task = engine.createRunAndRenderTask(design2);
options.setOutputStream(fso2);
task.run();
task.close();
concat( fso.toByteArray(), fso2.toByteArray(),
"output/resample/Combined.pdf");
engine.destroy();
Platform.shutdown();
System.out.println("Finished");
* @param args
try
CombineReportsPDF ex = new CombineReportsPDF( );
ex.runReport();
catch ( Exception e )
On 5/3/2011 11:22 AM, aca wrote:
> Thanks once again for the quick response!
> I have changed to using the runTask and renderTask and now the pageCount
> works perfect.
> One last (?) question:
> I have added an empty last page by creating an empty rptdesign and
> adding that to the bao list. This works just fine, but do you know of
> another smoother way to add an empty page to the reportDocument or the
> rendered pdf?
> Aca
Re: Double sided printing of multiple reports? [message #668627 is a reply to message #668097] |
Fri, 06 May 2011 09:31   |
Thanks a lot for the API, I've tried it and it works. For other reasons we did however choose to use an empty rpt-design instead, but I will save the API anyway
I'm having some problem with the pageCount which in tests turned out to be not so perfect. A printout with a dynamic list that is shown on two pages still returns a pagecount of 1. Any clue why?
Here is the create-method in which I have replaced RunAndRenderTask with a RunTask and a RenderTask.
public ByteArrayOutputStream createReport(String reportDesignName, String reportDocumentName, Object reportObject, Boolean printSettingDoubleSided)
throws ReportException {
ServletContext servletContext = WebHelper.getServletContext();
ByteArrayOutputStream pdfBaos = new ByteArrayOutputStream();
IRunTask runTask = null;
IRenderTask renderTask = null;
HashMap<String, Object> appContext = new HashMap<String, Object>();
appContext.put("reportObject", reportObject);
try {
IReportEngine engine = BirtEngine.getBirtEngine();
// RUN
String designHome = servletContext.getRealPath(ReportingConstants.REPORT_DESIGN_ PATH);
log.debug("RealPath to Birt report: " + designHome);
IReportRunnable report = engine.openReportDesign(designHome + reportDesignName);
runTask = engine.createRunTask(report);
runTask.setAppContext(appContext);
String documentHome = servletContext.getRealPath(ReportingConstants.REPORT_DOCUMEN T_PATH);
runTask.run(documentHome + reportDocumentName);
// RENDER
IReportDocument reportDocument = engine.openReportDocument(documentHome + reportDocumentName);
renderTask = engine.createRenderTask(reportDocument);
renderTask.setAppContext(appContext);
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler();
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(IRenderOption.OUTPUT_FORMAT_PDF);
options.setOutputStream(pdfBaos);
options.setImageDirectory("./images");
options.setImageHandler(imageHandler);
renderTask.setRenderOption(options);
renderTask.render();
long pageCount = reportDocument.getPageCount();
if(printSettingDoubleSided && pageCount % 2 > 0) {
//add an empty last page and concatenate into one baos
System.out.println(reportDesignName +" har udda antal sidor");
List<ByteArrayOutputStream> pdfBaosListTemporary = new ArrayList<ByteArrayOutputStream>();
pdfBaosListTemporary.add(pdfBaos);
pdfBaosListTemporary.add(createEmptyReport());
pdfBaos = concatPdfs(pdfBaosListTemporary, false);
reportDocument.close();
} catch(EngineException e) {
log.error(e.toString());
throw new ReportException("[createReport] Error when creating report:" + reportDesignName);
} catch(BirtException e) {
throw new ReportException("[createReport] Error when trying to create reportengine in creating report:"
} finally {
if(runTask != null) {
runTask.close();
if(renderTask != null) {
renderTask.close();
//return baos;
return pdfBaos;
Re: Double sided printing of multiple reports? [message #668667 is a reply to message #668627] |
Fri, 06 May 2011 12:04   |
Are you saying the reportDocument.getPageCount() method is only
returning 1? Can you reproduce with the sample db so I can run the
report here and have a look at it?
BTW if you are going to render to PDF you do not need to use
HTMLRenderOption. Use PDFRenderOption like:
options.setOption(IPDFRenderOption.PDF_HYPHENATION, true);
options.setOption(IPDFRenderOption.PDF_TEXT_WRAPPING, true);
options.setOption(IPDFRenderOption.PAGE_OVERFLOW,
IPDFRenderOption.FIT_TO_PAGE_SIZE);
//options.setOption(IPDFRenderOption.DPI, 300);
options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
options.setOutputFileName("output/resample/file2.pdf");
Jason
> save the API anyway :)
> try {
> // RUN
> String designHome =
> reportDesignName);
> // RENDER
> reportDesignName);
> } finally {
> runTask.close();
> renderTask.close();
> //return baos;
> return pdfBaos;
Re: (no subject) [message #669524 is a reply to message #668688] |
Tue, 10 May 2011 11:09  |
After changing the Layout preference to Fixed layout, the pageCount now works as expected for the generated pdf.
Thanks again for all the support!
Aca
FUDForum. Page generated in 0.06221 seconds
