Home » Archived » Buckminster » Import target definition problem with plugin version conflict
Import target definition problem with plugin version conflict [message #661341] Thu, 24 March 2011 06:23 Go to next message
I have 2 target platforms and my workspace is using both at once.
Plugin org.apache.commons.logging is included in both target directory. One is 1.0.04v201005080501 , one is 1.1.1v201005080502.
When importtargetdefinition I got an warning :
[WARNING 0005]: Component request org.apache.commons.logging :osgi.bundle[1.0.4v201005080501] is inconflct with request org.apache.commons.logging:osgi.bundle[1.1.1v201005080502]
With Buckminster installed from Mid Dec-2010 , the build continues and build successed.
But with current Buckminster, the upper version org.apache.commons.logging_1.1.1v2010205080502 is required to import to workspace. Consequence, I got error when importing resource :" Unable to find SearchPath for org.apache.commons.logging..."
In case, I want to keep both versions of this plugins in target platform. Is there any way to to let Bucky accept that?
Thanks in advance,
Hoang
Re: Import target definition problem with plugin version conflict [message #661351 is a reply to message #661341] Thu, 24 March 2011 06:41 Go to previous messageGo to next message
On 2011-03-24 11:23, Dao Hoang wrote:
I doubt that. The PDE target platform manager (and Buckminster) will only allow one active target platform at a time.
> 1.1.1v201005080502.
> Thanks in advance,
> Hoang
Bucky does accept that. What you see is a warning, not an error and it shouldn't be the cause of the "unable to find
SearchPath" message.
You should be aware though, that even if Bucky accepts it, chances are high that the target platform will never make the
lower version available to the build.
- thomas
Re: Import target definition problem with plugin version conflict [message #661356 is a reply to message #661351] Thu, 24 March 2011 07:04 Go to previous messageGo to next message
Thanks for your quick answer.
Bucky accepts both versions of the plugin. But as you said, the lower version may be not available in target platform with high chance. But in my case, the greater version seems to be not available and it is required to import to workspace. My searchPath, off couse, are not provided for target plug-ins.
I did not get any trouble with older version of Bucky.
Do you have any advise to make the build run again?
Thanks so much,
Hoang
Re: Import target definition problem with plugin version conflict [message #661362 is a reply to message #661356] Thu, 24 March 2011 07:15 Go to previous messageGo to next message
If you had an older version of Bucky, it's likely that you also had an older version of things that Bucky relies on (the
PDE target platform manager for instance), so pinning down exactly what's causing this behavior is difficult.
Unless you tell it not to, Buckminster will consult the *currently active* target platform during resolution. Is the
higher version of the bundle available there? I.e. can you see it being present when you view the active target platform
content using Preferences -> Plug-in Development -> Target Platform ?
- thomas
Re: Import target definition problem with plugin version conflict [message #661547 is a reply to message #661362] Fri, 25 March 2011 05:15 Go to previous messageGo to next message
> Is the higher version of the bundle available there?
> I.e. can you see it >being present when you view the active target
> platform content using Preferences -> Plug-in Development -> Target Platform ?
Sorry for my unclear description.
I meant that I have 2 target directories and used both of them in target platform. So the plug-ins duplication happened. This target platform is active and I can see both versions of the plugin in target platform.
But why Bucky asks to import it ( in my case it is the greater version) to workspace while both versions are available in target platform? Even though if only one is available, the greater version should be the one as you said. So I put a question in quite strange behavior.
Re: Import target definition problem with plugin version conflict [message #661565 is a reply to message #661547] Fri, 25 March 2011 07:41 Go to previous message
On 2011-03-25 10:15, Dao Hoang wrote:
>> Is the higher version of the bundle available there? I.e. can you see it >being present when you view the active
>> target platform content using Preferences -> Plug-in Development -> Target Platform ?
> This target platform is active and I can see both versions of the plugin in target platform. But why Bucky asks to
The error comes when Buckminster resolver ensures that the bundle can be found. If it is found in the TP, no import will
be done, so that part is probably OK.
> strange behavior.
I can take a look if you care to create an example that contains a target platform definition and projects needed to
reproduce the error and attach that to a bugzilla.
- thomas
Previous Topic:Howto exclude packages from the emma coverage report
Next Topic:target platform materialization with zipped components
Current Time: Sun Jul 20 17:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.04308 seconds
