Re: Create.product doesn't generate .exe and .ini files [message #661363 is a reply to message #661354] |
Thu, 24 March 2011 07:18  |
On 2011-03-24 12:02, Fabian Baboschi wrote:
> Very strange. This looks like a problem with the Hudson environment and buckminster. I created a copy of the project
> (with a different name) and it started to work magically. Then I renamed the working project to the old name, and the
> build stopped working. To me, this is a temporary file issue of the files that are actually put outside the temporary
> folders.
> I saw that there are some buckminster actions that use the /tmp folder (or c:\windows\temp - while downloading bundles).
> Can I specify what folder should be used by those actions also? (anything goes, even OS specific variable redefinition,
> I don't care)
Try setting:
buckminster.temp.root=<your preferred temp>
- thomas
FUDForum. Page generated in 0.03722 seconds
