Home » Eclipse Projects » Plugin Development Environment (PDE) » Product export-wizard problem(wizard does not generate launcher)
Product export-wizard problem [message #660917] Tue, 22 March 2011 06:50 Go to next message
I have developed an application made of four plug-ins:
- two are producing a DSL and its editor usint TMF-XText
- one uses the models specified by the DSL as an interpreter to run calculations and produce output
- one is the help system
It works fine from within my development Eclipse (SDK 3.6.1 and XText 2).
The runModel plugin includes a product definition including plashscreen and branding. It is based on two features, one with the four plugins of my application and and with all the other required plugins. It specifies that the application is org.eclipse.ui.ide.workbench.
The product runs fine from within the SDK.
When I try to export the product with the export wizard, it seems to work fine, except the the launcher exe does not get generated.
Any suggestion on what I might have missed is welcome.
MS
Re: Product export-wizard problem [message #666219 is a reply to message #660917] Tue, 19 April 2011 09:59 Go to previous message
So you created a product configuration, right? If you have, then open that file; what happens when you click on the 'Validate...' icon in the upper right (it's the one with the check box)?
Jon
Previous Topic:PDE product build with features : import cannot be resolved
Next Topic:Including jar from Plugin
Current Time: Sun Jul 20 03:27:01 EDT 2025
Powered by FUDForum. Page generated in 0.03129 seconds
