Home » Archived » M2M (model-to-model transformation) » [ATL] strange OCL behavior
[ATL] strange OCL behavior [message #660830] Mon, 21 March 2011 16:12 Go to next message
I'm currently writing some M2M transformations using ATL. One of the
helpers used during the M2M transformation is supposed to identify
operations with input parameters in the input model, e.g.:
parameters->exists(parameter | parameter.direction = #_in)
however, somehow this statement does not really do what it is supposed
to do, put another way, although the model contains operations with
input parameters, none of the is found. however, if I change "_in" to
"return", e.g.:
parameters->exists(parameter | parameter.direction = #return)
it suddenly works. So, my question, am I wrong in using "_in"?
Considering the OCL documentation it states explicitly that if there may
be ambiguities, as it would be with the word "in", if used in a query
and not as a keyword, and underscore has to be placed directly in front
of the ambiguous word, for that the proper meaning is derived, in this
case the meaning of the parameter direction kind (in) and not the OCL
keyword in. So again my question, what am I doing wrong that no
operation is found?
Philipp
Re: [ATL] strange OCL behavior [message #660874 is a reply to message #660830] Tue, 22 March 2011 04:26 Go to previous messageGo to next message
You're probably working with UML2 and ATL in which case the "in" is disambiguated by using #"in"
Re: [ATL] strange OCL behavior [message #660912 is a reply to message #660874] Tue, 22 March 2011 06:19 Go to previous messageGo to next message
hi sylvain,
i know about prepending the hash to the direction literal i'm querying,
if that was your hint. however, simply using #in gives an error in the
editor and still does not change anything at all, operations with input
parameters are not recognized.
cheers,
philipp
Re: [ATL] strange OCL behavior [message #660915 is a reply to message #660830] Tue, 22 March 2011 06:33 Go to previous messageGo to next message
My hint was about using the quotes around "in"
Re: [ATL] strange OCL behavior [message #660973 is a reply to message #660915] Tue, 22 March 2011 09:52 Go to previous message
hi sylvain,
sorry for getting your answer wrong, it now works!
thanks!
cheers,
philipp
Previous Topic:[ATL] Problem running a basic example
Next Topic:Re: [ATL] Debugger doesn't work
Current Time: Sun Jul 20 07:18:34 EDT 2025
Powered by FUDForum. Page generated in 0.03662 seconds
