Home » Eclipse Projects » Eclipse 4 » How to make the contacts demo more dynamic?
How to make the contacts demo more dynamic? [message #660576] Sat, 19 March 2011 11:31 Go to next message
The contact demo is very static in the sense that it has only one details view. Suppose one would like to make it more dynamic such that one click in the list view would
  • open an additional details view for the selected contact if a new contact is selected in the list view
  • set the focus on the appropriate details view if the selection on the list view is changed to a contact, for which a details view has been opened before
Furthermore, it should be possible to delete a details view. To summarize, the part stack for the details should behave like the editor area of the eclipse sdk.
How should one implement this? Should on create one MPart dynamically for every details view?
If yes, how should one delete this MPart? If I delete the details view in the demo (by clicking on the x in the folder of the GUI), an exception is thrown, the MPart is still part of the model, but it does no longer have an associated widget.
How does one have to create a separate context for every MPart, in order to add an "IEditorInput" to this context?
Will this context automatically be destroyed with the MPart?
Re: How to make the contacts demo more dynamic? [message #660605 is a reply to message #660576] Sat, 19 March 2011 17:09 Go to previous messageGo to next message
Am 19.03.11 08:31, schrieb Karl Weber:
> opened before
You'd use a MPartDescriptor and then use the EPartService to create
MPart-Instances from it.
The exception is coming from the custom code which tries to disable a
widget already disposed.
The framework (in this case the rendering engine) creates the
IEclipseContext for all MParts. The current code is getting the current
selection injected and I think that this might be the correct thing for
your example as well the only difference would be that you use
Constructor Injection whereas now Method Injection is used.
Yes, the rendering engine creates a child-context and when the element
is removed this very context is destroyed.
Tom
Re: How to make the contacts demo more dynamic? [message #661753 is a reply to message #660605] Sun, 27 March 2011 06:43 Go to previous messageGo to next message
Hi Tom, thanks for your Help!
Tom Schindl wrote on Sat, 19 March 2011 22:09
> opened before
I managed to define an MPartDescriptor in a fragment and open a corresponding MPart in a Part Stack of the application. So far, so good.
Now I have two further problems:
[1] I cannot open more than one MPart for the given MPartDescriptor. I need to open more than one. In the MPartDescriptor I have set allowMultiple=true. I thought, this would allow me, to open more than one instance of an MPart.
Edit 1: Somehow this problem disappeared. This leaves no [2].
[2] I need to intercept the creation of the MPart in order to add some object(s) (not strings) to its context before it gets created, so that I can use DI to provide this editor with some particular data. How can I do that? The following approach does not work, since part.getContext() return null.
	@Execute
	public void execute(EPartService partService) {
		if (partService != null) {
			MPart part = partService.createPart("de.gps.log.ui.mtkEditor");
			if (part != null) {
				IEclipseContext ctx = part.getContext();
                                // add something to the ctx here
				partService.showPart(part, PartState.ACTIVATE);
Edit 2: Seems I was a little hasty... The second problem seems to have disappeared as well: The solution described here http://www.eclipse.org/forums/index.php?t=msg&&th=16 1887&goto=511703 works.
[Updated on: Sun, 27 March 2011 09:44] by Moderator
Re: How to make the contacts demo more dynamic? [message #661765 is a reply to message #661753] Sun, 27 March 2011 12:42 Go to previous message
Am 27.03.11 03:43, schrieb Karl Weber:
>> > opened before
> one Instance of an MPart.
Not sure about this one and I'm just on holiday after EclipseCon so I'm
not able to take a look but maybe you hit a bug. So if noone else
responds in the next days I'd say you should file a bug.
> Object(s) to its context before it gets created, so that I can use DI to
> @Execute
> if (part != null) {
The part has no context until it gets rendered so that's why you get
null! You can always register an IContextFunctions using DS. You can
take a look at my model-tooling it does such a thing e.g. in
org.eclipse.e4.tools.emf.editor3x/OSGI-INF/xmiresourcecontex tfunction.xml.
Tom
Previous Topic:Splash progress bar
Next Topic:Some questions about savable parts
Current Time: Sat Jul 19 06:31:03 EDT 2025
Powered by FUDForum. Page generated in 0.05389 seconds
