Home » Modeling » GMF (Graphical Modeling Framework) » [solved]org.eclipse.emf.validation.ocl missing
[solved]org.eclipse.emf.validation.ocl missing [message #660399] Fri, 18 March 2011 06:21 Go to next message
Link constraints using OCL work fine, but when I add an audit container with an OCL constraint I get the error:
org.eclipse.emf.validation.ocl cannot be resolved
I'm new to using Eclipse and GMF and as such have no idea how to fix this. I've tried installing MDT/OCL 3.0.2, but this didn't help nor does it contain the required jar file.
Probably a beginners question and sorry if this is not the right place to ask...
[Updated on: Fri, 18 March 2011 09:29] by Moderator
Re: org.eclipse.emf.validation.ocl missing [message #660446 is a reply to message #660399] Fri, 18 March 2011 09:29 Go to previous message
Ok, I solved it already. Installed the OCL component through the Install New Software option as well as the EMF validation framework (it was already installed, but was now added as being installed).
Which of the two fixed it I don't know...
Previous Topic:[Solved] How To get the model from the EditPart?
Next Topic:ToolBarManager: remove subItem
Current Time: Sun Jul 20 06:25:25 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
