Home » Modeling » EMF » Proxy Resolution Problem
Proxy Resolution Problem [message #660373] Fri, 18 March 2011 03:42 Go to next message
Hi *,
I have the problem that proxies of single-valued references do not get
resolved, even though resolve proxies is true. As a result, migrations
specified in COPE/Edapt are not working. I debugged a lot and found the
following code snippet in EStructuralFeatureImpl:
2815 public static class
InternalSettingDelegateSingleEObjectResolvingUnsettable extends
2816 {
2817 public
InternalSettingDelegateSingleEObjectResolvingUnsettable(ECla ss eClass,
EStructuralFeature feature)
2818 {
2819 super(eClass, feature);
2820 }
2821
2822 @Override
2823 protected boolean isUnsettable()
2824 {
2825 return true;
2826 }
2827 }
Must the class InternalSettingDelegateSingleEObjectResolvingUnsettable
not inherit from InternalSettingDelegateSingleEObjectResolving instead
of InternalSettingDelegateSingleEObject? It seems to me that this only
affects reflective deserialization.
Thanks and cheers,
Markus
Re: Proxy Resolution Problem [message #660379 is a reply to message #660373] Fri, 18 March 2011 04:21 Go to previous messageGo to next message
Unfortunately, I cannot switch to the trunk version of EMF in some
projects. Is there a way to circumvent this problem, i.e. to force these
proxies to resolve?
Thanks.
Am 18.03.2011 08:42, schrieb Markus Herrmannsdoerfer:
> Hi *,
> 2816 {
> 2817 public
> 2818 {
> 2820 }
> 2821
> 2822 @Override
> 2824 {
> 2825 return true;
> 2826 }
> 2827 }
> Thanks and cheers,
> Markus
Re: Proxy Resolution Problem [message #660454 is a reply to message #660379] Fri, 18 March 2011 09:41 Go to previous message
Markus,
Yes, that looks wrong. Please open a bugzilla.
EStructuralFeature.Internal.setSettingDelegate can be used to set your
own setting delegate implementation into the feature that's not working
properly otherwise.
> these proxies to resolve?
> Thanks.
>> Hi *,
>> 2816 {
>> 2817 public
>> 2818 {
>> 2820 }
>> 2821
>> 2822 @Override
>> 2824 {
>> 2825 return true;
>> 2826 }
>> 2827 }
>> Thanks and cheers,
>> Markus
Previous Topic:Standalone EMF validation not registering constraints
Next Topic:Binding XML to java: serialization of mixed content cdata, text and comments
Current Time: Sun Jul 20 06:04:37 EDT 2025
Powered by FUDForum. Page generated in 0.07103 seconds
