Home » Archived » M2M (model-to-model transformation) » [ATL] Applying UML profile
[ATL] Applying UML profile [message #660304] Thu, 17 March 2011 14:04 Go to next message
Hi all,
I'm trying to apply a UML profile and stereotype to a UML sequence diag. giving my profile (Pro) as input model. But it raises this error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: OUT!CustomerInterface.getStereotype(java.lang.String)
at __applyLifeline#19(transApplied2.atl[40:22-40:49])
The ATL file:
module transApplied2;
create OUT : UML from IN : UML, Pro : UML;
helper def : getStereotype(name : String) : UML!Stereotype =
UML!Stereotype.allInstancesFrom('Pro')->select(p | p.name = name)->first();
rule Model {
from
s : UML!Model
to
t : UML!Model ( name <- s.name)
do {
t.applyProfile(UML!Profile.allInstancesFrom('Pro')->select(p | p.name = 'seqProTest1')->first()); }
rule Lifeline {
from
s : UML!Lifeline
to
t : UML!Lifeline (name <- s.name)
do {
t.applyStereotype(t.getStereotype('optional'));
--t.applyStereotype(t.getApplicableStereotype('seqProTest1:: optional')); }
Does anyone know why it couldn't find the operation getStereotype.
Thanks in advance,
Sally
Re: [ATL] Applying UML profile [message #660305 is a reply to message #660304] Thu, 17 March 2011 14:16 Go to previous messageGo to next message
The helper getStereotype is defined without context so to call it you have to use "thisModule" :
thisModule.getStereotype(str)
Re: [ATL] Applying UML profile [message #660340 is a reply to message #660305] Thu, 17 March 2011 21:24 Go to previous messageGo to next message
Thanks Sylvain. I still get the same error that "operation not found"
Re: [ATL] Applying UML profile [message #661402 is a reply to message #660340] Thu, 24 March 2011 10:35 Go to previous messageGo to next message
Your passing a UML!Stereotype into getStereotype(name : String) when the helper expects the stereotype name. This means ATL won't find a helper matching your signature.
Ronan
Re: [ATL] Applying UML profile [message #663429 is a reply to message #660304] Mon, 04 April 2011 22:43 Go to previous message
I modified to
t.applyStereotype(thisModule.getStereotype('optional'));
where optional is the stereotype name
I get this error
Operation not found: OUT!CustomerInterface.applyStereotype(org.eclipse.m2m.atl.en gine.emfvm.lib.OclUndefined)
The profile is correctly applied to the model, the problem with the operation applyStereotype.
I appreciate any hint.
Sally
Previous Topic:[ATL] String.split() method does not run
Next Topic:[QVTo] Logging DateTime
Current Time: Sat Jul 19 15:54:19 EDT 2025
Powered by FUDForum. Page generated in 0.05690 seconds
