Home » Modeling » M2T (model-to-text transformation) » [Xpand]define of the return type
[Xpand]define of the return type [message #659683] Tue, 15 March 2011 05:04 Go to next message
hi.
I want to call for a Java function in template, according to the related docs, firstly, I wrote the following code:
List[Entry<Integer,Integer>] funcname(paras)
then I wrote the function in another java file:
public List<Entry<Integer,Integer>> funcname(paras)
the return value I expected should be pairs of number, such as: 2, 3 or 3, 1.
however, in the .ext file, I got a error message:
mismatched input '<' expecting ']'
could you give me some suggestion?
[Updated on: Tue, 15 March 2011 05:08] by Moderator
Re: [Xpand]define of the return type [message #659694 is a reply to message #659683] Tue, 15 March 2011 05:42 Go to previous message
xpand/Xtend does not support nested generics so the returntype might be simply List[Entry]. At runtime you may Be able to downcast when iterating over the List.
~Christian
Previous Topic:[MWE2] Workflow execution fails randomly
Next Topic:[JET] Passing parameters from one method to another
Current Time: Sun Jul 20 02:35:03 EDT 2025
Powered by FUDForum. Page generated in 0.04794 seconds
