Home » Modeling » EMF » Defining ECore operations that return EList(problem with the returning type because EList is unmodificable)
Defining ECore operations that return EList [message #659673] Tue, 15 March 2011 04:21 Go to next message
Hi.
I want to define an operation on a particular element of my ecore metamodel, and the returning type must be a list of elements.
In the ecore editor, I select EEList<?> as the returning type but my problem is that I can't create that kind of lists, neither make a cast from ArrayList to EList.
If I had to return eContents from an EObject, I have be able to return an EList, but in my case, I have to return a list of element built by me.
(At the moment, I have got a non smart solution based on not to declare the returning type in the ecore editor, and after that I set ArrayList<?> as the returnint type in the signature of the implemented method.
Please, have you got any suggestion in order to get something smarter?
Thanks in advance.
Regards.
Carlos.
Re: Defining ECore operations that return EList [message #659714 is a reply to message #659673] Tue, 15 March 2011 05:57 Go to previous messageGo to next message
Originally posted by: koen.yskout.cs.kuleuven.be
Carlos,
You can set the EType to the type of the objects in the list, and set
the upper bound to -1.
Kind regards,
Koen
On 15/03/11 09:22, Carlos wrote:
> Hi.
> method.
> Thanks in advance.
> Regards.
> Carlos.
Re: Defining ECore operations that return EList [message #659715 is a reply to message #659673] Tue, 15 March 2011 05:58 Go to previous messageGo to next message
I use EEList as the return type and BasicEList as the implementation.
I.e. use BasicEList instead of ArrayList in the code that builds the result.
Hallvard
Re: Defining ECore operations that return EList [message #659750 is a reply to message #659714] Tue, 15 March 2011 09:45 Go to previous message
Hm, it looks like I completely misinterpreted your question :)
Using BasicEList, as Hallvard suggested, is probably the way to go.
On 15/03/11 10:57, Koen Yskout wrote:
> Carlos,
> Kind regards,
> Koen
>> Hi.
>> method.
>> Thanks in advance.
>> Regards.
>> Carlos.
Previous Topic:[Teneo] Using Hibernate Envers with Teneo
Next Topic:template proposals (ctrl+space)
Current Time: Sat Jul 19 21:56:30 EDT 2025
Powered by FUDForum. Page generated in 0.05050 seconds
