Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Running Pentaho Data Integration on Puppy Lucid 5.2
Running Pentaho Data Integration on Puppy Lucid 5.2 [message #659408] Sun, 13 March 2011 13:37 Go to next message
Hello, when I run the spoon application within Puppy Linux (Lucid 5.2), I get the following error and Pentaho Data Integration 4.0.1 (Kettle) will not start up. I've confirmed that I have Java JRE 6 version 22. However the same application runs fine in Puppy 4.3.1. Any ideas? Thanks.
# ./spoon.sh
INFO 09-10 05:19:35,553 - Using "/tmp/vfs_cache" as temporary files store.
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(Unknown Source)
at org.eclipse.swt.graphics.Font.init(Unknown Source)
at org.eclipse.swt.graphics.Font.<init>(Unknown Source)
at org.pentaho.di.ui.core.dialog.Splash$1.paintControl(Splash.j ava:127)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Control.gtk_expose_event(Unknown Source)
at org.eclipse.swt.widgets.Composite.gtk_expose_event(Unknown Source)
at org.eclipse.swt.widgets.Canvas.gtk_expose_event(Unknown Source)
at org.eclipse.swt.widgets.Widget.windowProc(Unknown Source)
at org.eclipse.swt.widgets.Control.windowProc(Unknown Source)
at org.eclipse.swt.widgets.Display.windowProc(Unknown Source)
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(Unknown Source)
at org.eclipse.swt.widgets.Display.eventProc(Unknown Source)
at org.eclipse.swt.internal.gtk.OS._gdk_window_process_updates( Native Method)
at org.eclipse.swt.internal.gtk.OS.gdk_window_process_updates(U nknown Source)
at org.eclipse.swt.widgets.Control.update(Unknown Source)
at org.eclipse.swt.widgets.Shell.setVisible(Unknown Source)
at org.eclipse.swt.widgets.Shell.open(Unknown Source)
at org.pentaho.di.ui.core.dialog.Splash.<init>(Splash.java:147)
at org.pentaho.di.ui.spoon.Spoon.main(Spoon.java:506)
at org.pentaho.commons.launcher.Launcher.main(Launcher.java:110 )
Re: Running Pentaho Data Integration on Puppy Lucid 5.2 [message #659412 is a reply to message #659408] Sun, 13 March 2011 14:06 Go to previous messageGo to next message
You've look at what kind of font is being requested in
org.pentaho.di.ui.core.dialog.Splash$1.paintControl(Splash.j ava:127)?
It's probably hard for anyone to comment without knowing what that line
of code is doing...
> ideas? Thanks.
> # ./spoon.sh
> store.
> Native Method)
> nknown Source)
Re: Running Pentaho Data Integration on Puppy Lucid 5.2 [message #659417 is a reply to message #659412] Sun, 13 March 2011 14:37 Go to previous messageGo to next message
Thanks for the quick response Ed. Could you please tell me where to possibly look? Would it be within 'spoon.sh' (below)? Or is it within Java files (127)? Thanks again.
#!/bin/sh
# ** Set these to the location of your mozilla
# ** installation directory. Use a Mozilla with
# ** Gtk2 and Fte enabled.
# set MOZILLA_FIVE_HOME=/usr/local/mozilla
# set LD_LIBRARY_PATH=/usr/local/mozilla
MOZILLA_FIVE_HOME=/usr/lib/xulrunner-1.8.1/
LD_LIBRARY_PATH=${MOZILLA_FIVE_HOME}:${LD_LIBRARY_PATH}
export MOZILLA_FIVE_HOME LD_LIBRARY_PATH
# Fix for GTK Windows issues with SWT
export GDK_NATIVE_WINDOWS=1
# ** Init BASEDIR **
BASEDIR=`dirname $0`
cd $BASEDIR
# ** Platform specific libraries ... **
JAVA_BIN=java
LIBPATH="NONE"
STARTUP="-jar launcher/launcher.jar"
case `uname -s` in
AIX)
LIBPATH=$BASEDIR/../libswt/aix/
SunOS)
LIBPATH=$BASEDIR/../libswt/solaris/
Darwin)
echo "Starting Data Integration using 'Spoon.sh' from OS X is not supported."
echo "Please start using 'Data Integration 32-bit' or"
echo "'Data Integration 64-bit' as appropriate."
exit
Linux)
ARCH=`uname -m`
case $ARCH in
x86_64)
if $($JAVA_BIN -version 2>&1 | grep "64-Bit" > /dev/null )
then
LIBPATH=$BASEDIR/../libswt/linux/x86_64/
else
LIBPATH=$BASEDIR/../libswt/linux/x86/
fi
i[3-6]86)
ppc)
LIBPATH=$BASEDIR/../libswt/linux/ppc/
echo "I'm sorry, this Linux platform [$ARCH] is not yet supported!"
exit
esac
FreeBSD)
ARCH=`uname -m`
case $ARCH in
x86_64)
LIBPATH=$BASEDIR/../libswt/freebsd/x86_64/
exit
i[3-6]86)
LIBPATH=$BASEDIR/../libswt/freebsd/x86/
ppc)
LIBPATH=$BASEDIR/../libswt/freebsd/ppc/
exit
exit
esac
HP-UX)
LIBPATH=$BASEDIR/../libswt/hpux/
CYGWIN*)
./Spoon.bat
exit
echo Spoon is not supported on this hosttype : `uname -s`
exit
esac
export LIBPATH
# ** Set java runtime options **
# ** Change 256m to higher values in case you run out of memory. **
OPT="$OPT -Xmx256m -Xms256m -XX:MaxPermSize=128m -Djava.library.path=$LIBPATH -DKETTLE_HOME=$KETTLE_HOME -DKETTLE_REPOSITORY=$KETTLE_REPOSITORY -DKETTLE_USER=$KETTLE_USER -DKETTLE_PASSWORD=$KETTLE_PASSWORD -DKETTLE_PLUGIN_PACKAGES=$KETTLE_PLUGIN_PACKAGES -DKETTLE_LOG_SIZE_LIMIT=$KETTLE_LOG_SIZE_LIMIT"
# ** Run... **
$JAVA_BIN $OPT $STARTUP -lib $LIBPATH "${1+$@}"
Re: Running Pentaho Data Integration on Puppy Lucid 5.2 [message #659499 is a reply to message #659417] Mon, 14 March 2011 06:42 Go to previous messageGo to next message
No the important thing is the JavaCode in this line:
I'd suggest you ask at the pentaho newsgroup, ... for help. We can't do
anything here to help you get out of this.
Tom
Am 13.03.11 19:37, schrieb jlalicata2000@yahoo.com:
> #!/bin/sh
> cd $BASEDIR
> JAVA_BIN=java
> LIBPATH="NONE"
> case `uname -s` in AIX)
> SunOS) LIBPATH=$BASEDIR/../libswt/solaris/
> Darwin)
> not supported."
> exit
> Linux)
> ARCH=`uname -m`
> case $ARCH in
> x86_64)
> then
> else
> fi
> i[3-6]86)
> ppc)
> supported!"
> exit
> esac
> FreeBSD)
> ARCH=`uname -m`
> case $ARCH in
> x86_64)
> supported!"
> exit
> i[3-6]86)
> ppc)
> supported!"
> exit
> supported!"
> exit
> esac
> HP-UX) LIBPATH=$BASEDIR/../libswt/hpux/
> CYGWIN*)
> ./Spoon.bat
> exit
> *) echo Spoon is not supported on this hosttype : `uname -s`
> exit
> esac
> export LIBPATH
> # ** Run... **
Re: Running Pentaho Data Integration on Puppy Lucid 5.2 [message #659699 is a reply to message #659499] Tue, 15 March 2011 06:01 Go to previous message
Thanks Tom. Will do!
Previous Topic:Update TrayIcon Tooltip on Windows
Next Topic:How to wrap text in a Label
Current Time: Sat Jul 19 19:52:20 EDT 2025
Powered by FUDForum. Page generated in 0.04966 seconds
