Installing Android SDK with Eclipse 3.6.2 [message #659382] |
Sun, 13 March 2011 03:37  |
So this is what I have done so far. I installed Java SE JDK and then installed the Android SDK and all the components that it wanted to install by default. I installed Eclipse classic 3.6.2. But when I try to update intalled software on eclipse. I am told from instructions to https://dl-ssl.google.com/android/eclipse/ and install the 4 components that it finds there. 3 of them install and the 4th one which is the "Android Development Tools for Eclipse". This one didnt install. It said components missing. I read some forums and it said I have to put in http://download.eclipse.org/releases/galileo in the sites and I did that. But there was so many things on that url that I started installing whatever I could find. Now it seems to want to install but there is a conflict below. I cant figure out what two things are conflicting where where to remove the conflict. Is it in eclipse or is it in Android SDK manager? Any help would be greatly appreciated.
Cannot complete the install because of a conflicting dependency.
Software being installed: Android Development Tools 10.0.0.v201102162101-104271 (com.android.ide.eclipse.adt.feature.group 10.0.0.v201102162101-104271)
Software currently installed: Shared profile 1.0.0.1297373395076 (SharedProfile_SDKProfile 1.0.0.1297373395076)
Only one of the following can be installed at once:
International Components for Unicode for Java (ICU4J) 4.2.1.v20100412 (com.ibm.icu 4.2.1.v20100412)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090822 (com.ibm.icu 4.0.1.v20090822)
International Components for Unicode for Java (ICU4J) 4.0.1.v20090415 (com.ibm.icu 4.0.1.v20090415)
Cannot satisfy dependency:
From: Shared profile 1.0.0.1297373395076 (SharedProfile_SDKProfile 1.0.0.1297373395076)
To: com.ibm.icu [4.2.1.v20100412]
From: Android Development Tools 10.0.0.v201102162101-104271 (com.android.ide.eclipse.adt.feature.group 10.0.0.v201102162101-104271)
To: org.eclipse.wst.xml.ui 0.0.0
From: Java EMF Model Utilities 2.0.200.v200905140200 (org.eclipse.jem.util 2.0.200.v200905140200)
To: bundle com.ibm.icu [3.8.1.1,4.1.0)
From: Java EMF Model Utilities 2.0.201.v201001252130 (org.eclipse.jem.util 2.0.201.v201001252130)
From: Common Frameworks 1.1.300.v200904160730 (org.eclipse.wst.common.frameworks 1.1.300.v200904160730)
To: bundle org.eclipse.jem.util [2.0.100,3.0.0)
From: Validation Framework 1.2.102.v200905201610 (org.eclipse.wst.validation 1.2.102.v200905201610)
To: bundle org.eclipse.wst.common.frameworks [1.1.200,2.0.0)
From: Validation Framework 1.2.104.v200911120201 (org.eclipse.wst.validation 1.2.104.v200911120201)
From: Eclipse XML Editors and Tools 1.1.1.v200908242115 (org.eclipse.wst.xml.ui 1.1.1.v200908242115)
To: bundle org.eclipse.wst.validation [1.2.0,1.3.0)
From: Eclipse XML Editors and Tools 1.1.2.v201001222130 (org.eclipse.wst.xml.ui 1.1.2.v201001222130)
Re: Installing Android SDK with Eclipse 3.6.2 [message #661187 is a reply to message #660078] |
Wed, 23 March 2011 09:56  |
On 3/16/11 2:10 PM, Tash wrote:
> Can you give me the address for the 3.6 version repository?
If you install one of the Helios packages (Helios is based on Eclipse
3.6), then the Helios repository is pre-configured; you just have to
select it in the Install New Software window.
Eric
FUDForum. Page generated in 0.08931 seconds
