Home » Eclipse Projects » Eclipse Platform » Dynamically load class at runtime(Class.forName("xy") not possible?)
Dynamically load class at runtime [message #659133] Fri, 11 March 2011 03:12 Go to next message
I am working on an eclipse plugin and I need to load a directory into the classpath at runtime. It's only possible at runtime!
I tried to do the following:
public static void addDirectoryToClassPath(String pDirectory) throws Exception {
		File lDirectoryToAdd = new File(pDirectory);
		if(!lDirectoryToAdd.exists() || !lDirectoryToAdd.isDirectory()) {
			throw new Exception(pDirectory + " doesn't exist or isn't a directory!");
		} else {
			Thread lCurrentThread = Thread.currentThread();
			ClassLoader lOldClassLoader = lCurrentThread.getContextClassLoader();
			URL[] lDirectoryURL = new URL[] {lDirectoryToAdd.toURI().toURL()};
			URLClassLoader lNewClassLoader = new URLClassLoader(lDirectoryURL, lOldClassLoader);
			lCurrentThread.setContextClassLoader(lNewClassLoader);
But if I try to load the class later via
Class.forName("classname);
I get a CLassNotFoundException.
For Information: I will load the class in another eclipse plugin, but that's not the problem at the moment because even in the same plugin Class.forName("") doesn't work...
I would appreciate any help
Thanks in advance
Alex
Re: Dynamically load class at runtime [message #659156 is a reply to message #659133] Fri, 11 March 2011 05:11 Go to previous messageGo to next message
Dealing with contextClassLoader in OSGi is quite difficult!
You'd rather keep a reference to your classloader and use lNewClassLoader.loadClass("") rather than Class.forName("");
HTH
Mickael Istria -- BonitaSoft S.A.
http://www.bonitasoft.com/products/BPM_download.php
Re: Dynamically load class at runtime [message #659157 is a reply to message #659133] Fri, 11 March 2011 05:20 Go to previous messageGo to next message
Hello and first of all thanks for your answer!
That's not as easy as it seems because the Class.forName statment is not within the same plugin.
Plugin A should add some directories to the classpath whilst plugin B is loading those classes.
Changing the functionality of Plugin B from Class.forName() to your suggestion isn't programmed properly, is it?
No other way than changing plugin B?
Re: Dynamically load class at runtime [message #659198 is a reply to message #659133] Fri, 11 March 2011 08:04 Go to previous messageGo to next message
You cannot do it the way you describe. Eclipse plugins are OSGi
bundles. That means that OSGi provides a framework classpath with
almost nothing, and the framework wires up the classes a bundles can
see, based on the MANIFEST.MF Require-Bundle or Import-Package
To dynamically load classes, you'll have to do some hand waving.
Are these JDBC drivers? There are probably examples out there of install
JDBC drivers into an RCP app, maybe http://www.eclipse.org/datatools has
some tips.
But in general, you need to use a bundle to load your classes into OSGi.
example:
1) if you are creating a directory with classes/jars at runtime, make it
a bundle by including a META-INF/MANIFEST.MF. Then use your
BundleContext to install it.
2) if it's a known library that will be installed on the client system
(you just can't know where) you can ship a bundle with a MANIFEST.MF
that uses the external: $INTERESTING_DIR$/lib/whatever.jar directive in
its Bundle-ClassPath. When installing on the client system, you can
simple add -DINTERESTING_DIR to the .ini file and it will pick up the
installed lib.
There are also runtime options that would allow you to add to the system
classpath or boot classpath, but they require restarting to update.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Dynamically load class at runtime [message #659464 is a reply to message #659198] Mon, 14 March 2011 03:34 Go to previous messageGo to next message
Hello Paul and thanks for your answer first!
No, its not for JDBC support. I programmed a debugger based on a 4th Generation Language and java.
Plugin A is the builder which should set up the classpath and call the compiler if necessary.
Plugin B is the compiler and should load classes dynamically via the classpath set up by Plugin A.
Your suggestion to solve the problem via the .ini file is quite difficult, because the classpath is dynamic. I can add libraries during runtime and some other things.
I'm just able to get the whole classpath right before Plugin A calls Plugin B. Not earlier,
Kind regards
Alex
Re: Dynamically load class at runtime [message #659519 is a reply to message #659464] Mon, 14 March 2011 07:56 Go to previous message
JDT doesn't actually load the java source that it's working with or
compiling into its own JVM. It creates an AST and works with that.
Since this isn't really applicable to your running environment, why
wouldn't you just create a URLClassLoader and pass that to your compiler
plugin?
Yes, restarting is useful for a install time problem, not dynamically
changing classpaths ... OSGi is useful for that, but I'm not sure you're
playing in the right space.
Why does your plugin need something in its classpath? I'm pretty sure
that other tools work without loading their stuff into their own JVM.
PW
Paul Webster
Previous Topic:Re: Main menu drop down event and mouse hover on Main menus.
Next Topic:building eclipse with javac
Current Time: Sat Jul 19 19:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.03518 seconds
