Remove Title from generated EMF editor [message #658950] |
Thu, 10 March 2011 09:41  |
How can I remove the title "Resource Set" generated in the EMF Editor?
Ps.: I tried to change the method createPages in the generated editor, removing the ViewerPane (Like the Ecore editor do), but with this i loose the linkage with the properties tab.
Re: Remove Title from generated EMF editor [message #658958 is a reply to message #658950] |
Thu, 10 March 2011 09:51  |
Wagner,
The title is determined by the label of the input object to the view.
So you could specialize the ResourceSetItemProvider that's created via
the ResourceItemProviderAdapterFactory, or you might use a new
ItemProvider() instance with the children and label you want as input
(though contents changes of the resource set will no longer update the
view).
Wagner Paz wrote:
FUDForum. Page generated in 0.04008 seconds
