Home » Modeling » MoDisco » Operating/editing the results of a query
Operating/editing the results of a query [message #657833] Fri, 04 March 2011 04:01 Go to next message
I'm working on a project for creating an EMF facade to an(y) Java
(legacy) API. The idea is to allow a developer to operate on EMF object,
and automatically sync the corresponding Java (legacy) objects.
To avoid hand-coding, I'm trying to use Modisco to discover various
patterns of get/set/add/remove methods in the Java API, so I can
generate both the EMF facade classes and the mapping strategy. Since the
API is fairly large (in fact it's SWT) I try to "prune" the model, so
I've created queries that retrieve the non-public methods (irrelevant
for the facade). I get a result set, but now I want to remove those
objects from the model. Is this possible? If not directly, what's the
easiest way of doing this?
Hallvard
Re: Operating/editing the results of a query [message #658252 is a reply to message #657833] Mon, 07 March 2011 10:01 Go to previous messageGo to next message
in EMF Java API, you can remove EObjects from Java models with
EcoreUtil.delete(EObject eObject, boolean recursive) service. Indicating
a recursive delete is prefered for deleting references to contained objects.
notice that the java model will be no more valid when some eobjects are
deleted. e.g. if you delete some private method, some MethodInvocation
instances pointing to it from one java statement will be invalid. It may
not be important in your use case if you do not care of Java statements
in method bodies.
F.
Le 04/03/2011 10:01, Hallvard Trætteberg a écrit :
> Hallvard
Re: Operating/editing the results of a query [message #658377 is a reply to message #658252] Tue, 08 March 2011 04:27 Go to previous messageGo to next message
> objects.
I was mostly wondering if there was possible to execute commands or
queries on the result set in the UI. E.g. first query for objects, then
do something useful on them.
> in method bodies.
Yes. Another command/query that could be useful is find all references
to an object, so you can analyse dependencies.
BTW, is it possible to execute new queries on a result set (in the UI)?
Hallvard
Re: Operating/editing the results of a query [message #658618 is a reply to message #658377] Wed, 09 March 2011 04:43 Go to previous messageGo to next message
on the Model Query Results table view, it is possible to select one
resulting EObject and execute another query (which may have a
side-effect on model).
Until now, you cannot execute such a request from the result table UI in
one shot on all objects.
Notice that queries implementations may invoke themselves together, so
that a command query may start with a call to another selection query.
Fabien.
Re: Operating/editing the results of a query [message #658809 is a reply to message #658618] Wed, 09 March 2011 16:21 Go to previous message
I solved it by creating a specific deletion query, corresponding to a
selection query. However, if it was possible to execute a query on all
the objects, in the table, i.e. allow multiple selection as is possible
in the main view, I could use a generic deletion query on the result of
the selection.
Yes, that makes it possible to avoid duplicating code.
Hallvard
Previous Topic:Integrating support for Javascript
Next Topic:csv is not reachable
Current Time: Sat Jul 19 14:17:13 EDT 2025
Powered by FUDForum. Page generated in 0.25802 seconds
