[EEF] FeatureMap entry binary name [message #656513] |
Fri, 25 February 2011 20:43  |
Running the "Generate EEF Architecture" on my eefgen file produces source with many of these errors:
The nested type org.eclipse.emf.ecore.util.FeatureMap$Entry cannot be referenced using its binary name
on code like this in in the generated components:
* Used to update the views
protected void runUpdateRunnable(final Notification msg) {
if (AmlPackage.eINSTANCE.getAnnotation_Mixed().equals(msg.getFeature()) && basePart != null) {
if (msg.getEventType() == Notification.ADD)
basePart.addToMixed((org.eclipse.emf.ecore.util.FeatureMap$Entry) msg.getNewValue());
else if (msg.getEventType() == Notification.REMOVE)
basePart.removeToMixed((org.eclipse.emf.ecore.util.FeatureMap$Entry) msg.getNewValue());
if (AmlPackage.eINSTANCE.getAnnotation_Id().equals(msg.getFeature()) && basePart != null){
if (msg.getNewValue() != null) {
basePart.setId(EcoreUtil.convertToString(XMLTypePackage.eINSTANCE.getString(), msg.getNewValue()));
} else {
basePart.setId("");
and on code like this in the generated parts:
* Add a value to the group multivalued attribute.
* @param newValue the value to add
public void addToGroup(org.eclipse.emf.ecore.util.FeatureMap$Entry newValue);
I have about 300 of these errors in my build, but have exhausted my ideas about how to repair the problem. Has anyone else solved an issue like this?
Re: [EEF] FeatureMap entry binary name [message #658177 is a reply to message #656514] |
Mon, 07 March 2011 05:03   |
Hi Matt,
Ed is right, it's a bug. I'm sorry, I can't give you a work around. Can
you open a bug, I will fix it for 1.0.
Goulwen Le Fur - goulwen.lefur@obeo.fr
Le 26/02/2011 03:21, Ed Merks a écrit :
> Matt,
> It sounds like a bug. In the generated Java source, the "$" should be
> replaced with a ".". EMF's generator's importer would have produced
> FeatureMap.Entry.
>> if
>> (AmlPackage.eINSTANCE.getAnnotation_Mixed().equals(msg.getFe ature())
>> basePart.addToMixed((org.eclipse.emf.ecore.util.FeatureMap$E ntry)
>> msg.getNewValue());
> I would have expected removeFrom not removeTo for more meaningful
> English...
>> if (AmlPackage.eINSTANCE.getAnnotation_Id().equals(msg.getFeatu re())
> I would have expected == to be used for feature comparison (it performs
> better and must be equivalent), and for
> AmlPackage.LITERALS.ANNOTATION__ID to be used (if available) for better
> performance
>> basePart.setId(EcoreUtil.convertToString(XMLTypePackage.eINS TANCE.getString(),
>> } else {
>> basePart.setId("");
>> newValue);
>> like this?
FUDForum. Page generated in 0.04312 seconds
