Home » Eclipse Projects » EGit / JGit » Internal error GitDecoratorJob NullPointerException(I get an internal error when I try to use EGit)
Internal error GitDecoratorJob NullPointerException [message #658024] Sat, 05 March 2011 02:28 Go to next message
I got this error when I tried to deploy EGit in my project:
An internal error occurred during: "GitDecoratorJob[/Users/nyholku/jDraftProject/.git]".
this is with the latest Helios and EGit
Eclipse JGit (Incubation) 0.11.3 org.eclipse.jgit.feature.group
Eclipse SDK 3.6.2.M20110210-1200 org.eclipse.sdk.ide
Anything I could try or should I file a bug?
br Kusti
Re: Internal error GitDecoratorJob NullPointerException [message #658230 is a reply to message #658024] Mon, 07 March 2011 08:59 Go to previous messageGo to next message
Hi Kusti,
please open a bug with the stacktrace of the Exception from the Eclipse
Error Log view.
Thanks and Best Regards,
Stefan
"Kustaa Nyholm" <kustaa.nyholm@planmeca.com> wrote in message
news:iksoad$mjm$1@news.eclipse.org...
> br Kusti
Re: Internal error GitDecoratorJob NullPointerException [message #658241 is a reply to message #658024] Mon, 07 March 2011 09:49 Go to previous message
Hi Stefan,
thanks for answering. I will see if I can re-procude the case (to generate the stack trace) as I've 'solved' the problem.
The problem was that there was file in the project which I think was actually a link/alias and which was somehow damaged. I could not even delete it from the workspace/project. In the end I opened the '.project' file and deleted every reference to that file, I think it was in a section called 'linked something'
I will see if my Time Machine has a copy of the damager .project file so I can file a proper bug report.
Anyway, it looks clear that GitDecoratorJob chokes on a bad file in the 'project' and does not gracefully ignore or report it.
br Kusti
Previous Topic:Team -> Share Project not decorating associating with Git Repostiory
Next Topic:How to use Merge Tool
Current Time: Sat Jul 19 12:35:29 EDT 2025
Powered by FUDForum. Page generated in 0.06471 seconds
