Home » Modeling » OCL » [CompleteOCL]definition uses definition
[CompleteOCL]definition uses definition [message #632189] Mon, 11 October 2010 22:54 Go to next message
hi, all:
I am new to OCL.. I tried to reuse definitions in OCL. For example, in CompleteOCL editor:
def: criteria1(c:Integer):Boolean = c > 90 and c < 100
def: criteria2(c:Integer):Boolean = c > 80 and c < 95
def: check(r:Integer):Boolean = criteria1(r) and criteria2(r)
The editor could not resolve criteria1 and criteria2 in check. Does the OCL specification allow such reuse of defintions? Is this only a bug specific to the editor? Thanks!
Liu Qiang
Re: [CompleteOCL]definition uses definition [message #632197 is a reply to message #632189] Tue, 12 October 2010 00:50 Go to previous messageGo to next message
Hi Liu
Yes, this is a known bug in the editor.
The underlying Java support should work, and indeed if you save the file
and put it through the
[The OCL specification indeed specifies that such reuse of definitions
is allowed, but unfortunately neglects to provide a mechanism for an AST
with such reuse to be persisted. A solution to the specification is
currently being prototyped within MDT/OCL and this will solve the editor
problem too.]
Ed Willink
On 12/10/2010 03:54, Liu Qiang wrote:
> hi, all:
> CompleteOCL editor:
> Liu Qiang
Re: [CompleteOCL]definition uses definition [message #657923 is a reply to message #632197] Fri, 04 March 2011 11:00 Go to previous messageGo to next message
Im also interested in the workaround for this bug, but apparently the answer got cut ("put it through the...").
-Juan Cadavid
Re: [CompleteOCL]definition uses definition [message #657985 is a reply to message #657923] Fri, 04 March 2011 14:26 Go to previous messageGo to next message
Hi Juan
Sorry. The complete answer was "put it through the LPG (rather than
Xtext) parser".
This is fixed in the new release. M6 available in about 2 weeks. The new
release also removes forward/backward resolution problems.
Ed Willink
On 04/03/2011 16:00, Juan Cadavid wrote:
> -Juan Cadavid
Re: [CompleteOCL]definition uses definition [message #658179 is a reply to message #657985] Mon, 07 March 2011 05:14 Go to previous message
Great news! Thank you Smile
-Juan
Previous Topic:OCL Context and UML Usage relationship
Next Topic:Bug in OCL or in my code?
Current Time: Sat Jul 19 09:15:59 EDT 2025
Powered by FUDForum. Page generated in 0.06049 seconds
