Home » Modeling » TMF (Xtext) » Hook for creation and destruction of EObject
icon5.gif  Hook for creation and destruction of EObject [message #656750] Mon, 28 February 2011 07:49 Go to next message
According to Sven's proposal I create additional EObject during linking. But due to limitation with forward/cyclic references this is too late.
It would be perfect to create the additional EObjects after normal creation of an EObject as a result of parsing.
1. Is there a hook called which is called for each EObject identified by the parser before linking?
2. Is there a hook which is called an Object is removed from source?
Marco
Re: Hook for creation and destruction of EObject [message #657894 is a reply to message #656750] Fri, 04 March 2011 09:32 Go to previous messageGo to next message
Any suggestion would be much appreciated.
Marco
Re: Hook for creation and destruction of EObject [message #657913 is a reply to message #656750] Fri, 04 March 2011 10:14 Go to previous messageGo to next message
Hi Marco,
sorry, your message somehow slipped through the net.
1) Have a look at IAstFactory#create . The instance is not fully
initialized, though. AbstractCleaningLinker#beforeModelLinked should be
a better match for your usecase.
2) Please register a EContentAdapter in the resource to get such a
notification.
However, I'd recommend to implement something along those lines:
AbstractCleaningLinker#beforeModelLinker:
remove any dynamically created instance from your model.
DefaultLinkingService#getLinkedObjects(EObject, EReference, INode):
create instances dynamically if the returned list is empty.
Sebastian
Am 28.02.11 13:49, schrieb Marco:
> Marco
Re: Hook for creation and destruction of EObject [message #657937 is a reply to message #657913] Fri, 04 March 2011 11:50 Go to previous messageGo to next message
Hi Sebastian,
I implemented exactly what you suggested, but the problem then is with forward references. Consider this simplified example:
def x = ref y + 1
def y = ref x - 1
def something is actually a reference to the declaration of something which is created when linking def something.
So when xtext tries to link ref y it fails because def y is not yet linked and therefore dec y not yet created. I am not sure about forward reference, but it I am sure for cyclic references.
Marco
Re: Hook for creation and destruction of EObject [message #658091 is a reply to message #656750] Sun, 06 March 2011 04:54 Go to previous messageGo to next message
So it would be perfect if I could influence the linking so that defs are linked before refs, or the I can defer linking of ref until all other linking done if it fails.
/m
Re: Hook for creation and destruction of EObject [message #658093 is a reply to message #658091] Sun, 06 March 2011 05:14 Go to previous messageGo to next message
The perfect place to create the shadow objects seem to be the MyDslFactoryImpl#createDef.
But it seems that the uses of MyDslFactoryImpl and MyDslPackageImpl are hardcoded. So I cannot register my own versions, right?
Is there another way to customize the createDef methode in MyDslFactoryImpl?
Marco
Re: Hook for creation and destruction of EObject [message #658115 is a reply to message #658093] Sun, 06 March 2011 11:44 Go to previous messageGo to next message
IAstFactory#create is not really a good place as it does not know anything about the EObject to create.
IAstFactory#set is a little bit better because it receives at least the node from which I can get the name of the dec to create. But still neither the node nor the EObject is yet linked to a Resource. And without the resource I do not know in which scope the dec should be placed.
Any more suggestions?
Thanks.
MArco
Re: Hook for creation and destruction of EObject [message #658216 is a reply to message #658091] Mon, 07 March 2011 07:37 Go to previous messageGo to next message
You could hook into
org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObjec t(String)
to create the EObject if it cannot be created the proxy resolution.
Am 06.03.11 10:54, schrieb Marco:
> /m
Re: Hook for creation and destruction of EObject [message #658271 is a reply to message #658216] Mon, 07 March 2011 11:39 Go to previous message
Jan,
Thanks for the answer. But I do not understand how this could help.
Wouldn't it be in the same call chain for each reference to be linked as DefaultLinkingService#getLinkedObjects(EObject, EReference, INode)?
Marco
Previous Topic:Deploying plugin succeeds, editor does not show
Next Topic:Generated editor and text field
Current Time: Sat Jul 19 15:25:38 EDT 2025
Powered by FUDForum. Page generated in 0.26317 seconds
