Home » Modeling » UML2 » The ID of a UML element
The ID of a UML element [message #657583] Thu, 03 March 2011 06:13 Go to next message
Does the UML metamodel provide any way to access the ID of an element? They often look like this in the XML:
<element xmi:type="uml:OpaqueAction" href="SomeModel.uml#_dmKHMDjwEeCH9LLYtylVBA"/>
The ID being the part after the '#'.
I'm trying to access the ID in a QVTo transformation, isn't it the metamodel that provides the methods for accessing data like this, rather than the transformation language itself?
[Updated on: Thu, 03 March 2011 06:16] by Moderator
Re: The ID of a UML element [message #657706 is a reply to message #657583] Thu, 03 March 2011 11:47 Go to previous messageGo to next message
Haffi,
eObject.eResource().getURIFragment(eObject) should return the ID.
Haffi wrote:
> They often look like this in the XML: <element
Re: The ID of a UML element [message #657817 is a reply to message #657706] Fri, 04 March 2011 03:44 Go to previous messageGo to next message
I think that may be true for cross resource references only, right?
Doesn't this work for all cases?
((XMIResource) resource).getID(eObject)
Rafael
http://abstratt.com/blog
[Updated on: Fri, 04 March 2011 03:45] by Moderator
Re: The ID of a UML element [message #657907 is a reply to message #657817] Fri, 04 March 2011 09:45 Go to previous message
Rafael,
Comments below.
The code eObject.eResource().getURIFragment(eObject) doesn't even care
whether anything references that object... Note however, that it will
return the ID if there's an ID but will always return a non-null result
such that
eObject.eResource().getEObject(eObject.eResource().getURIFra gment(eObject))
== eObject.
This only works in cases where you're contained in an XMIResource. It
will return null if the eObject doesn't have an ID.
Previous Topic:UML2 and the OMG Model Interchange Working Group (MIWG)
Next Topic:uml diagram question
Current Time: Sat Jul 19 11:07:01 EDT 2025
Powered by FUDForum. Page generated in 0.07185 seconds
