[databinding] How to validate multiple properties cross-referenced [message #657567] |
Thu, 03 March 2011 05:19  |
first of all, I'm a JFace newbie, so I kindly ask forgiveness if I ask a dummy question.
Suppose to have a model with three (integer) properties: a minimum value (min), a maximum value (max), and a default value (d). Obviously, these properties must satisfy the following two constraints:
(1) each of them must be a number
(2) min <= d <= max
I'm writing a JFace wizard so to allow the user to create an instance of such model.
Since I would like to provide the user with a notification about the errors in his inputs, I leverage the JFace validation framework, and I'm able to warn the user if he inserts an invalid number.
However, I'm stuck with the second constraint... how can I validate it?
Matteo
Re: [databinding] How to validate multiple properties cross-referenced [message #658240 is a reply to message #657567] |
Mon, 07 March 2011 09:47  |
As outlined in my other response you can't do this with IValidators on
the UpdateValueStrategy. The only possible solution is to implement an
IValidationStatusProvider on your DatabindingContext.
Tom
Am 03.03.11 11:19, schrieb Matteo:
> dummy question.
> (2) min <= d <= max
> such model. Since I would like to provide the user with a notification
> Matteo
FUDForum. Page generated in 1.03351 seconds
