Re: Eclipse for PHP Developers Helios Service Release 2 Now Available [message #657128 is a reply to message #656920] |
Tue, 01 March 2011 11:48   |
Toshihiro Izumi wrote on Mon, 28 February 2011 19:47 | I noticed another issue...
Toggle Comment, Add/Remove Block Comment, they don't work in PHP Editor.
I added bug fixed plugin org.eclipse.php.ui_2.2.1.v20101001-2300.jar.
Try it when you were blown down by this malfunction.
I've used your patch, and it works well. Please remember to start eclipse with --clean option.
I'm really tired of pdt releases with major bugs. I do not get it how this can go trough QA. With the frequency at which pdt is released, these releases need to be bug free, or at least major bug free. Users should not be required to dig thru forums to find patches. Also, whenever a release has bugs of this magnitude, an update should be released ASAP...
I really do like eclipse pdt, and I think it's a great IDE in general, and I appreciate that it's free. However, there is no reason why an open source project should not have high quality standards.
Anyways, thanks to Toshihiro Izumi for a great patch !
Re: Eclipse for PHP Developers Helios Service Release 2 Now Available [message #758899 is a reply to message #758694] |
Fri, 25 November 2011 01:43  |
>"Feature Patch for PDT 2.2.1.v20101001-2300" is not applicable to the current configuration and will not be installed.
This message simply means you are not allowed to use "Feature Patch for PDT 2.2.1.v20101001-2300".
It requires the feature,
Name: PHP Development Tools (PDT) Runtime Feature
Identifier: org.eclipse.php.feature.group
Version: 2.2.1.v20101001-2300-7L7J1F8NcJTJTJJT9cmJJ
Eclipse says you don't have it.
No problem.
FUDForum. Page generated in 0.09702 seconds
