Home » Modeling » EMF » UnresolvedReferenceException an ID
UnresolvedReferenceException an ID [message #657412] |
Wed, 02 March 2011 12:33  |
I was performing some test with the XMLResource when i run into some troubles.
I have created a model with a non-containment reference. Which i know is going to fail when i call save.
I also pass the option XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD to prevent the save from throwing an exception.
When i load the model there are no errors an everything is fine.
However this behaviour changes a lot when the object to which the non-containment reference refers has one attribute set to ID.
On the Save:
- No errors are shown or exception is thrown.
On the Load:
- the UnresolvedReferenceException is thrown regardless of the option XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD
Could anyone give me some hints on how is the best way to deal with this scenario in order to have similar behaviour when ID is set to true than when is set to false.
Thanks in advance!
Re: UnresolvedReferenceException an ID [message #657450 is a reply to message #657436] |
Wed, 02 March 2011 14:47   |
Comments below.
Xavipen wrote:
> Hi Ed,
> Thanks for your quick response.
> Quote:
>> Xavipen,
>> Comments below.
>> >Xavipen wrote:
>> > Hi,
>> some > troubles.
>> know > is going to fail when i call save.
>> XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD > to prevent the save
>> > However this behaviour changes a lot when the object to which the >
>> > On the Save:
>> It just uses the ID in that case I guess?
> Yes, it uses the id.
> The issue that i see is that you do not get any indication that
> something was missing and you may thing everything is fine with the
> model when you save it.
> I would have though that this would be checked like is done when the
> ID is not use and null would have been set in that case, so the load
> would not fail.
> Two more things consecuence of the above:
> 1) Is there any option to prevent the load from throwing an Exception?
> . The XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD doesn't do the
> trick :cry:
No, but keep in mind that the resource is fully loaded and available for
use...
> 2) Checking the dignostic messages return when loading i see that
> another valid object which is persisted has a diagnostic of
> IllegalValueException. Maybe here i should add that the
> "unresolvedreference" is within a list.
> Quote:
>> > On the Load:
>> option > XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD >
>> It's better to use things like EcoreUtil.delete to remove objects and
>> all references to them.
> Thanks for the the hint EcoreUtil.delete will be quite handy. :) And
> i would definetely use it.
> Unfortunatelly my concern when setting up this set of tests was to see
> how the persistance would behave in case there where
> hanging/unresolved references. So the model could be loaded again and
> regardless error the save a load would set the hanging references to
> null. This works pretty well when the ID is not use but not quite when
> is use.
> I could send the test case if you want
I'm not keen on adding checks during serialization. It's quite
expensive to determine if an object is contained by a resource. For an
HREF, we have to do that check anyway to build a cross resource URI, but
for an IDREF, we don't.
If you want to be sure you save only good instances, you should use
Diagnostician.INSTANCE.validate to find all the problems. E.g., to
find cases where more than one object has the same ID.
>> Thanks in advance!
>> [/quote]
> Cheers,
Re: UnresolvedReferenceException an ID [message #657466 is a reply to message #657450] |
Wed, 02 March 2011 15:45   |
Ed,
Comments below.
Xavipen wrote:
> > Hi Ed,
> > Quote:
>> >> Xavipen,
>> >> Comments below.
>>> >> >Xavipen wrote:
>>> >> > Hi,
>> >> some > troubles.
>>> >> > On the Save:
> > would not fail.
> > trick
> use...
> > Quote:
>>> >> > On the Load:
> > Thanks for the the hint EcoreUtil.delete will be quite handy. And
> > is use.
>> >> Thanks in advance!
>> >> [/quote]
> > Cheers,
I understand your point about not adding the check and i could live with no getting any error, although is not ideal. (Diagnostician.INSTANCE.validate does not raise any error neither)
However, it seems to be a problem with the load of the resource loaded from the test model.
I maybe able to explain it better with an example.
The Model is as follow
The root object has two list contaiment lit of Class A and B. B has itself a non contaiment list of Objects A.
model is:
root
-> list ( A1, A4 )
-> list (B1, B2)
where:
B1 --> (A1,A2)
B2 --> (A1,A2,A3,A4)
I save it and then load it. The model loaded is fine except for B2.
instead of having B2--> (A1,A4)
it has B2 --> (A1)
So the reference to one valid object is also lost becasue of the unresolved references. This seems a bit Odd.
Re: UnresolvedReferenceException an ID [message #657483 is a reply to message #657466] |
Wed, 02 March 2011 18:01   |
--------------090104060404090201080008
Comments below.
Xavipen wrote:
> Ed,
> Comments below.
> Xavipen wrote:
>> > Hi Ed,
>> > Quote:
>>> >> Xavipen,
>>> >> Comments below.
>>>> >> >Xavipen wrote:
>>>> >> > Hi,
>>> >> some > troubles.
>>> save >> from throwing an exception.
>>>> the >
>>>> >> > On the Save:
>> > The issue that i see is that you do not get any indication that >
>> something was missing and you may thing everything is fine with the >
>> the > ID is not use and null would have been set in that case, so the
>> load > would not fail.
>> Exception? > . The XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD
>> doesn't do the > trick :cry:
>> for use...
>> > 2) Checking the dignostic messages return when loading i see that >
>> another valid object which is persisted has a diagnostic of >
>> IllegalValueException. Maybe here i should add that the >
>> > Quote:
>>>> >> > On the Load:
>>> >> option > XMIResource.OPTION_PROCESS_DANGLING_HREF_RECORD > >>
>>>> with >> > this scenario in order to have similar behaviour when ID
>>>> is set to >> > true than when is set to false.
>>> and >> all references to them.
>> And > i would definetely use it.
>> see > how the persistance would behave in case there where >
>> to > null. This works pretty well when the ID is not use but not
>> quite when > is use.
> an HREF, we have to do that check anyway to build a cross resource
> URI, but for an IDREF, we don't.
>>> >> Thanks in advance!
>>> >> [/quote]
>> > Cheers,
Hmmm. EObjectValidator has this logic:
public boolean validate_EveryReferenceIsContained(EObject eObject,
DiagnosticChain diagnostics, Map<Object, Object> context)
boolean result = true;
if (eObject.eResource() != null)
for (EContentsEList.FeatureIterator<EObject> i =
(EContentsEList.FeatureIterator<EObject>)eObject.eCrossReferences().iterator();
i.hasNext(); )
EObject eCrossReferenceObject = i.next();
if (eCrossReferenceObject.eResource() == null &&
!eCrossReferenceObject.eIsProxy() && !i.feature().isTransient())
So for any object contained by a resource, if it has any cross
references not contained by a resource, there will be an error
produced. So I'm a little doubtful... that you'd not see a diagnostic.
Note that using Resource.getAllContents() and using
EObject.eCrossReferences() on each contained object, it's very easy to
check if eResource() is null for any of those (like what the above is
doing).
> model is:
> root
> -> list ( A1, A4 )
> -> list (B1, B2)
> where:
> B1 --> (A1,A2)
> it has B2 --> (A1)
If it's really important in your application to trap this, you could
specialize your ResourceImpl to check for "eObject.eResource() == this"
and return "/-1" if it's false.
public String getURIFragment(EObject eObject)
String id = EcoreUtil.getID(eObject);
if (id != null)
return id;
> Cheers,
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Comments below.<br>
<br>
Xavipen wrote:
<blockquote cite="mid:ikm9ta$mj6$1@news.eclipse.org" type="cite">Ed,
<br>
<br>
Comments below.
<br>
<br>
Xavipen wrote:
<br>
<blockquote type="cite">> Hi Ed,
<br>
<br>
<br>
<br>
> Quote:
<br>
<blockquote type="cite">>> Xavipen,
<br>
<br>
>> Comments below.
<br>
<br>
<blockquote type="cite">>> >Xavipen wrote:
<br>
>> > Hi,
<br>
<br>
run into </blockquote>
>> some > troubles.
<br>
<br>
Which i </blockquote>
<br>
<blockquote type="cite">>> > I also pass the option </blockquote>
prevent the save >> from throwing an exception.
<br>
<blockquote type="cite">>> > When i load the model there
<br>
<br>
which the > </blockquote>
<br>
<br>
>> > On the Save:
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
<br>
the > model when you save it.
<br>
the load > would not fail.
<br>
<br>
<br>
for use...
<br>
<br>
<br>
> Quote:
<br>
<br>
>> > On the Load:
<br>
of the </blockquote>
<br>
<br>
deal with >> > this scenario in order to have similar
behaviour when ID is set to >> > true than when is set to
false.
<br>
</blockquote>
objects and >> all references to them.
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
I'm not keen on adding checks during serialization. It's quite </blockquote>
<br>
<br>
<blockquote type="cite">If you want to be sure you save only good
instances, you should use </blockquote>
<br>
<br>
<br>
>> Thanks in advance!
<br>
>> [/quote]
<br>
</blockquote>
<br>
> Cheers,
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
Hmmm. EObjectValidator has this logic:<br>
<blockquote><small> public boolean
validate_EveryReferenceIsContained(EObject eObject, DiagnosticChain
diagnostics, Map<Object, Object> context)</small><br>
<small> {</small><br>
<small> boolean result = true;</small><br>
<small> if (eObject.eResource() != null)</small><br>
<small> for (EContentsEList.FeatureIterator<EObject> i =
(EContentsEList.FeatureIterator<EObject>)eObje ct.eCrossReferences().iterator();
i.hasNext(); )</small><br>
<small> EObject eCrossReferenceObject = i.next();</small><br>
<small> if (eCrossReferenceObject.eResource() == null
&& !eCrossReferenceObject.eIsProxy() &&
!i.feature().isTransient())</small><br>
</blockquote>
diagnostic. Note that using Resource.getAllContents() and using
doing).<br>
<blockquote cite="mid:ikm9ta$mj6$1@news.eclipse.org" type="cite"><br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
model is:
<br>
root
<br>
-> list ( A1, A4 )
<br>
-> list (B1, B2)
<br>
<br>
where:
<br>
B1 --> (A1,A2)
<br>
<br>
<br>
<br>
<br>
<br>
it has B2 --> (A1)
<br>
<br>
<br>
</blockquote>
and return "/-1" if it's false.<br>
<blockquote><small> public String getURIFragment(EObject eObject)</small><br>
<small> String id = EcoreUtil.getID(eObject);</small><br>
<small> if (id != null)</small><br>
<small> return id;</small><br>
<small> }</small><br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------090104060404090201080008--
Re: UnresolvedReferenceException an ID [message #657655 is a reply to message #657638] |
Thu, 03 March 2011 10:31  |
Ed,
The corrected code, I had mistaken one == for one !=. My apologies. I hope that know it would be easier to understand my question.
Quote: | Javi,
Commens below.
Xavipen wrote:
> Hi Ed,
> I have followed your indications and started having a look to
> specialize the ResourceImpl. I check code of the method you said and i
> believe i understand its logic but for one thing.
> Why check eObject.eResource() == this and not for eObject.eResource()
> == null?
Where are you referring to?
> likewise
> container.eDirectResource() == this and not
> container.eDirectResource() == null?
Where?
> At the end of the day if an object is contained by another resource it
> should be also ok. What i am missing?
I'm not sure.
I was talking about the ResourceImpl and the method getURIFragement
if (id != null)
return id;
so the specialize method would be:
if (id != null)
if ( eObject.eResource()== this){
return id;
}else{
return "/-1";
Why check eObject.eResource() == this and not for eObject.eResource() != null?
likewise if id == null the rest of the code on that method for ResourceImpl checks for container.eDirectResource() == this and not container.eDirectResource() != null?
if (internalEObject.eDirectResource() == this || unloadingContents != null && unloadingContents.contains(internalEObject))
return "/" + getURIFragmentRootSegment(eObject);
else
At the end of the day if an object is contained by another resource it should be also ok. What i am missing?
[Updated on: Thu, 03 March 2011 19:45] by Moderator
Current Time: Sat Jul 19 10:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.05555 seconds
