Home » Modeling » EMF » [CDO] CDO4 depends on which EMF version?
[CDO] CDO4 depends on which EMF version? [message #657291] Wed, 02 March 2011 05:55 Go to next message
I'm trying to run CDO HEAD from SVN. I'm seeing some compile errors, for example in org.eclipse.emf.cdo EresourceSwitch is missing org.eclipse.emf.ecore.util.Switch.
The cdo manifest requires org.eclipse.emf.ecore[2.4.0,3.0.0). Shouldn't this be [2.7.0...?
Does this actually mean that CDO 4.0 will require EMF 2.7 when released?
Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657304 is a reply to message #657291] Wed, 02 March 2011 06:09 Go to previous messageGo to next message
Gergely,
we just regenerated our models a few days ago, and apparently
org.eclipse.emf.ecore.util.Switch concept was recently introduced in
EMF. Our goals is trying to stay as much compatible as possible, but
probably the minimum version should be 2.6.0, as CDO relies on some new
features of EMF to implement the Legacy Model Support.
So, right now TRUNK does require 2.7.0, but we inted to be 2.6.0
compatible. I'll recommend you to switch to the revision before that
change was introduced (which I believe happened 2 days ago).
We'll post here some feedback as soon as we know how to deal with the
Switch thing ;)
Víctor.
> this be [2.7.0...?
> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657317 is a reply to message #657304] Wed, 02 March 2011 07:30 Go to previous messageGo to next message
Thanks Victor!
I'm trying to test a feature introduced yesterday, so I guess I'll try to upgrade to 2.7 in my development environment. It is good to know that compatibility will remain with 2.6 though, as that is what our product is currently based on. In any case, the manifests will need to be updated from 2.4, shall I file a bug about this?
Greg
Victor Roldan Betancort wrote on Wed, 02 March 2011 12:09
Gergely,
Switch thing Wink
Víctor.
> this be [2.7.0...?
> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657323 is a reply to message #657317] Wed, 02 March 2011 07:49 Go to previous messageGo to next message
Gergely,
> Thanks Victor!
you are welcome!
I assume at this point of the development is very unlikely that
dependencies with 2.7.0 would be introduced. We (Open Canarias) also
rely on 2.6.0, so we are very interested this compatibility to be kept.
I really haven't tested if CDO 4.0 is compatible with < 2.6.x, but
chances are it won't (as I said previously, EMF mechanisms to make
Legacy Support feasible are a good example). Maybe the others could
confirm this.
So yes, please submit that bug, it shall serve us at least as a
reminder! Please make clear in the zilla evidences are necessary for the
version range to be narrowed.
Cheers!
>> Gergely,
>> new features of EMF to implement the Legacy Model Support.
>> Switch thing ;)
>> Cheers,
>> Víctor.
>> for
>> > this be [2.7.0...?
>> released?
>> > Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657329 is a reply to message #657291] Wed, 02 March 2011 08:16 Go to previous messageGo to next message
Guys,
This breaking change in EMF was entirely new to me and I even did not realize it when it happened.
I'm not sure how to deal with this as we can certainly not stop to regenerate our internal models in response to evolution of our models or of EMF itself.
The best solution would be if we could switch off this new switch (how ironic!). Ed, what do you think?
Cheers
/Eike
http://www.esc-net.de
Am 02.03.2011 11:55, schrieb Gergely Nagy:
> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657340 is a reply to message #657329] Wed, 02 March 2011 08:22 Go to previous messageGo to next message
Perhaps we can influence that with the "Runtime Version" property in the GenModel...
Cheers
/Eike
Am 02.03.2011 14:16, schrieb Eike Stepper:
> Guys,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657341 is a reply to message #657340] Wed, 02 March 2011 08:26 Go to previous messageGo to next message
Am 02.03.2011 14:22, schrieb Eike Stepper:
Yes, that helped. I've committed the change in the context of bug 338508.
Cheers
/Eike
> Cheers
> /Eike
>> Guys,
>> Cheers
>> /Eike
>>> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657353 is a reply to message #657341] Wed, 02 March 2011 09:14 Go to previous messageGo to next message
Great, thanks Eike :D
>> the GenModel...
> Cheers
> /Eike
>> Cheers
>> /Eike
>>> Guys,
>>> or of EMF itself.
>>> Cheers
>>> /Eike
>>>> released?
>>>> Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657392 is a reply to message #657323] Wed, 02 March 2011 10:48 Go to previous messageGo to next message
--------------010904080803080503090407
Víctor,
<rant>
Your comment
is one of the things that bugs me most about all these "hard coded"
version ranges in the source repository. The lower bound is set once
and then it's not updated again, nor (worst of all) is it ever tested to
check if it's valid. So lower bounds degrade into bogusness quickly
from release to release. The upper bound, on the other hand, is an
assertion that "I expect to stop working at some point." It's
completely baseless forecasting of the future; about as accurate as
Vancouver weather forecasting. Should the version ever change to exceed
the asserted upper bound, the first thing you need to do is sweeping
updates of the upper bounds to even try it out (to even run tests),
which generally turns out to reveal all is working fine.
</rant>
Víctor Roldán Betancort wrote:
> Gergely,
>> Thanks Victor!
> you are welcome!
> confirm this.
> the version range to be narrowed.
> Cheers!
>>> Gergely,
>>> Switch thing ;)
>>> Cheers,
>>> Víctor.
>>> for
>>> Shouldn't
>>> > this be [2.7.0...?
>>> released?
>>> > Greg
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Víctor,<br>
<br>
&lt;rant&gt;<br>
<br>
Your comment<br>
<blockquote>I really haven't tested if CDO 4.0 is compatible with &lt;
2.6.x<br>
</blockquote>
to check if it's valid.  So lower bounds degrade into bogusness quickly
exceed the asserted upper bound, the first thing you need to do is
sweeping updates of the upper bounds to even try it out (to even run
tests), which generally turns out to reveal all is working fine.<br>
<br>
&lt;/rant&gt;<br>
<br>
<br>
<blockquote cite="mid:ikle10$1qj$1@news.eclipse.org" type="cite">Gergely,
<br>
<br>
<br>
<blockquote type="cite">Thanks Victor!
<br>
</blockquote>
<br>
you are welcome!
<br>
<br>
<blockquote type="cite">I'm trying to test a feature introduced
<br>
that
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite">In any case, the manifests will need to be
<br>
<br>
</blockquote>
<br>
I really haven't tested if CDO 4.0 is compatible with &lt; 2.6.x, but
confirm this.
<br>
<br>
<br>
<br>
Cheers!
<br>
<br>
<blockquote type="cite">Victor Roldan Betancort wrote on Wed, 02
March 2011 12:09
<br>
<blockquote type="cite">Gergely,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Switch thing ;)
<br>
<br>
<br>
Víctor.
<br>
<br>
<br>
&gt; I'm trying to run CDO HEAD from SVN. I'm seeing some compile
errors,
<br>
for
<br>
&gt; example in org.eclipse.emf.cdo EresourceSwitch is missing
<br>
&gt; org.eclipse.emf.ecore.util.Switch.
<br>
&gt;
<br>
&gt; The cdo manifest requires org.eclipse.emf.ecore[2.4.0,3.0.0).
Shouldn't
<br>
&gt; this be [2.7.0...?
<br>
&gt;
<br>
&gt; Does this actually mean that CDO 4.0 will require EMF 2.7 when
<br>
released?
<br>
&gt;
<br>
&gt; Greg
<br>
&gt;
<br>
</blockquote>
<br>
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------010904080803080503090407--
Re: [CDO] CDO4 depends on which EMF version? [message #657399 is a reply to message #657392] Wed, 02 March 2011 11:36 Go to previous messageGo to next message
I do agree to some extent. Vik, would you like to volunteer for the creation of new Hudson jobs downstream to our integration job. These jobs should take what's been built, deploy it into the older targets that we claim to be compatible with and run the tests. Adolfo seems to become a Buckminster expert, he might be helpful ;-)
Cheers
/Eike
Am 02.03.2011 16:48, schrieb Ed Merks:
> Víctor,
> <rant>
> Your comment
> is one of the things that bugs me most about all these "hard coded" version ranges in the source repository. The lower bound is set once and then it's not updated again, nor (worst of all) is it ever tested to check if it's valid. So lower bounds degrade into bogusness quickly from release to release. The upper bound, on the other hand, is an assertion that "I expect to stop working at some point." It's completely baseless forecasting of the future; about as accurate as Vancouver weather forecasting. Should the version ever change to exceed the asserted upper bound, the first thing you need to do is sweeping updates of the upper bounds to even try it out (to even run tests), which generally turns out to reveal all is working fine.
> </rant>
>> Gergely,
>>> Thanks Victor!
>> you are welcome!
>> I assume at this point of the development is very unlikely that dependencies with 2.7.0 would be introduced. We (Open Canarias) also rely on 2.6.0, so we are very interested this compatibility to be kept.
>> I really haven't tested if CDO 4.0 is compatible with < 2.6.x, but chances are it won't (as I said previously, EMF mechanisms to make Legacy Support feasible are a good example). Maybe the others could confirm this.
>> So yes, please submit that bug, it shall serve us at least as a reminder! Please make clear in the zilla evidences are necessary for the version range to be narrowed.
>> Cheers!
>>>> Gergely,
>>>> Switch thing ;)
>>>> Cheers,
>>>> Víctor.
>>>> for
>>>> > this be [2.7.0...?
>>>> released?
>>>> > Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657716 is a reply to message #657392] Thu, 03 March 2011 12:10 Go to previous messageGo to next message
Ed,
I can only agree with your comments. Its something we should take better
care of! We shall set some mechanisms to systematically test version
range compatibility. As Eike suggest, a Hudson build with properly
selected bundle versions should help. Can you think on any way to test
this in our Eclipse development environments, besides switching target
platform?
Cheers.
Ed Merks escribió:
> Víctor,
> <rant>
> Your comment
> </rant>
>> Gergely,
>>> Thanks Victor!
>> you are welcome!
>> confirm this.
>> Cheers!
>>>> Gergely,
>>>> Switch thing ;)
>>>> Cheers,
>>>> Víctor.
>>>> for
>>>> Shouldn't
>>>> > this be [2.7.0...?
>>>> released?
>>>> > Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657719 is a reply to message #657399] Thu, 03 March 2011 12:26 Go to previous messageGo to next message
I'll look for some time for it!
> Cheers
> /Eike
>> Víctor,
>> <rant>
>> Your comment
>> </rant>
>>> Gergely,
>>>> Thanks Victor!
>>> you are welcome!
>>>> that
>>> confirm this.
>>> Cheers!
>>>>> Gergely,
>>>>> Switch thing ;)
>>>>> Cheers,
>>>>> Víctor.
>>>>> for
>>>>> Shouldn't
>>>>> > this be [2.7.0...?
>>>>> released?
>>>>> > Greg
Re: [CDO] CDO4 depends on which EMF version? [message #657745 is a reply to message #657716] Thu, 03 March 2011 14:22 Go to previous messageGo to next message
Am 03.03.2011 18:10, schrieb Víctor Roldán Betancort:
> Ed,
> I can only agree with your comments. Its something we should take better care of! We shall set some mechanisms to systematically test version range compatibility. As Eike suggest, a Hudson build with properly selected bundle versions should help. Can you think on any way to test this in our Eclipse development environments, besides switching target platform?
Switching the target platform looks like the minimum requirement ;-)
Cheers
/Eike
> Cheers.
> Ed Merks escribió:
>> Víctor,
>> <rant>
>> Your comment
>> </rant>
>>> Gergely,
>>>> Thanks Victor!
>>> you are welcome!
>>> confirm this.
>>> Cheers!
>>>>> Gergely,
>>>>> Switch thing ;)
>>>>> Cheers,
>>>>> Víctor.
>>>>> for
>>>>> Shouldn't
>>>>> > this be [2.7.0...?
>>>>> released?
>>>>> > Greg
(no subject) [message #687524 is a reply to message #657291] Tue, 21 June 2011 09:23 Go to previous messageGo to next message
Hi all,
I have a similar issue. I'm trying to upgrade to CDO 4.0 GA. We
currently have EMF 2.5. org.eclipse.emf.cdo imports
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.EObservableAdapterList
which appeared in EMF 2.6. But the Manifest still has 2.4 as minimum
requirement.
Bug?
Cyril
> this be [2.7.0...?
> Greg
(no subject) [message #687526 is a reply to message #687524] Tue, 21 June 2011 12:24 Go to previous messageGo to next message
Originally posted by:
Hi guys,
I think this issue slipped through our fingers. AFAIK, CDO 4.0 has
compatibility with 2.6 (we at OpenCanarias use such configuration in one
of our products).
This is a severe problem, and too late in the development cycle :(
Do you mind submiting a bug to keep track of it?
I'm also afraid increasing the version range implies increasing CDO
version to 5.0....
Víctor.
Cyril Jaquier escribió:
> Hi all,
> requirement.
> Bug?
> Thanks
> Cyril
>> this be [2.7.0...?
>> Greg
(no subject) [message #687532 is a reply to message #687526] Wed, 22 June 2011 02:37 Go to previous messageGo to next message
Am 21.06.2011 18:24, schrieb Víctor Roldán Betancort:
> Hi guys,
> AFAIK, CDO 4.0 has
> of our products).
Yes, since CDO 3.0 were a bound to EMF 2.6 since the Legacy Mode,
introduced in CDO 3.0, needs EMF 2.6
Martin
(no subject) [message #687536 is a reply to message #687526] Wed, 22 June 2011 04:18 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=350015
Cyril
Previous Topic:[CDO] access CDO server in same JVM like CDO Sessions view
Next Topic:Generated diagram code does not respect interface name pattern - bug?
Current Time: Sat Jul 19 04:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.06152 seconds
