Home » Modeling » Modeling (top-level project) » model autosave
model autosave [message #656655] |
Sun, 27 February 2011 18:55  |
I want to save automatically the model shortly after modification to a
temporary location to salvage as much as possible in the [un]likely
event of a crash.
In order to do so I attached a ChangeAdapter to the model:
getResource().setTrackingModification(true);
mta = new ChangeMonitor();
getResource().eAdapters().add(mta);
where:
private final class ChangeMonitor extends AdapterImpl {
public void notifyChanged(Notification msg) {
super.notifyChanged(msg);
synchronized (saveDate) {
changeDate = new Date();
if (saveJob == null) {
saveJob = new Job("saveJob") {
protected IStatus run(IProgressMonitor monitor) {
Date now = new Date();
System.out.println("saveJob():");
if (tmp == null)
try {
newTmp();
} catch (FileNotFoundException e) {
return new Status(Status.ERROR,
"it.condarelli.writer.model", "saveJob(): unable to get tmp file:
'"+e.getMessage()+"'");
saveTmp();
if (changeDate.before(now)) {
changeDate = null;
} else {
if (saveTmpDelay > 0)
saveJob.schedule(saveTmpDelay);
saveDate = now;
return Status.OK_STATUS;
} else {
saveJob.cancel();
if (saveTmpDelay >= 0)
where newTmp() computes a suitable temp-file in "File tmp;" and the guts
of saveTmp() are:
public void saveTmp() {
File t = null;
try {
OutputStream os = new FileOutputStream(tmp);
try {
Map<String, String> opt = new HashMap<String, String>();
opt.put(XMLResource.OPTION_ENCODING, "UTF-8");
resource.save(os, opt);
os.close();
} catch (IOException e) {
This blows up because resource.save(...) does change something inside,
so ChangeMonitor.notifyChanges() is called recursively.
At the very least errors and warnings are reset.
I can (obviously) filter the changes using "Notification msg", but I am
not sure if this ie the "Right Way"(TM) to do this.
What I want to achieve is:
1) monitor changes to model.
2) wait a fixed amount of time after last change (e.g.: 1 min).
3) when timeout expired without further changes (model is "idle") save
it to a temp location.
4) when a "Save" operation is requested either save (if some unsaved
modifications exist) or rename the saved temporary to the "right"
resource name; in any case the temporary should be removed.
Is the above the right approach?
What changes should I filter out as "uninteresting" housekeeping (as
opposed to real changes in model contents?
Side issue:
I a lot of troubles because EMF defines its own URI class, but that is
not compatible with java.io.File
I ended up doing this quite often:
if (uri.isFile()) {
File f = new File(uri.toFileString());
if (f.exists())
f.delete(); // or f.renameTo(...) or some other File op.
Is this the right way to go?
Thanks for any comments.
Mauro
Re: model autosave [message #656828 is a reply to message #656655] |
Mon, 28 February 2011 12:57   |
Mauro,
Comments below.
Mauro Condarelli wrote:
> event of a crash.
You could just listen to the stack since changes must happen as a result
of executing a command.
> where:
> @Override
> @Override
> if (tmp == null)
> try {
> newTmp();
> saveTmp();
> changeDate = null;
> } else {
> saveDate = now;
> } else {
> saveJob.cancel();
> guts of saveTmp() are:
> File t = null;
> try {
> try {
> os.close();
> am not sure if this ie the "Right Way"(TM) to do this.
Listening to the command stack would be way more efficient.
> Side issue:
Because more often than not, you're dealing with platform:/resource
which uses IFile which might not even exist in the file system
depending on the EFS implementation.
> if (uri.isFile()) {
> if (f.exists())
Aren't you dealing with workspace resources?
> Regards
> Mauro
Re: model autosave [message #656850 is a reply to message #656828] |
Mon, 28 February 2011 14:06   |
Thanks Ed,
Comments below.
Il 28/02/2011 18:57, Ed Merks ha scritto:
> Mauro,
> Comments below.
>> Hi,
>> event of a crash.
Sorry, I fail to understand You.
I have a complex model which is essentially a tree I edit in three
different ways:
1) some commands that let me insert new nodes in the tree; Later on I
want to add dreg&drop command to implement prune&graft in the tree.
2) each node type has it's own page (built around FormToolkit in
master/detail) and widgets are directly bound to model via EMF DataBinding.
3) a specific field is actually a kind of a source text and is edited
using a specialized AbstractTextEditor; upon saving this is stored in
the TEXT of one model fields (<content>Here goes the TextEditor
contents</content>).
Which "command stack" should I listen to? (please forgive me for being
naive, I'm not really an eclipse guru).
>> where:
>> @Override
>> @Override
>> if (tmp == null)
>> try {
>> newTmp();
>> return new Status(Status.ERROR, "it.condarelli.writer.model",
>> "saveJob(): unable to get tmp file: '"+e.getMessage()+"'");
>> saveTmp();
>> changeDate = null;
>> } else {
>> saveDate = now;
>> } else {
>> saveJob.cancel();
>> File t = null;
>> try {
>> try {
>> os.close();
A more detailed pointer would be *very* welcome. TiA!
>> Side issue:
> which uses IFile which might not even exist in the file system depending
Uhm... not my case; see below.
>> if (uri.isFile()) {
>> if (f.exists())
No.
I am editing a file in the normal filesystem (eventually over a net, but
that is not the problem). I have no workspace concept.
To give You an idea: I am doing something similar to MS-Word: I have a
complex document I need to edit and then to save in a single file that
can be moved, sent to others, reopened and re-edited using my app (or
some other app that understands the same XML schema; actually there was
another app I inherited, then I started a complete rewrite using RCP,
but the on-disk XML is basically the same).
I am calling my app with "-data @user.home/.Writer" to save Preferences
in a known place, but the actual file can be anywhere.
>> Regards
>> Mauro
Mauro
Re: model autosave [message #656872 is a reply to message #656850] |
Mon, 28 February 2011 15:28   |
Mauro,
Comments below.
> Thanks Ed,
> Comments below.
>> Mauro,
>> Comments below.
>>> Hi,
>>> event of a crash.
If you look at the generated EMF editor, you'll see there's a command
stack listener already for updating the editor's dirty state.
> different ways:
> DataBinding.
For your editor to support undo properly, you must already be using a
command stack (I assume).
>>> where:
>>> @Override
>>> @Override
>>> if (tmp == null)
>>> try {
>>> newTmp();
>>> saveTmp();
>>> changeDate = null;
>>> } else {
>>> saveDate = now;
>>> } else {
>>> saveJob.cancel();
>>> File t = null;
>>> try {
>>> try {
>>> os.close();
See the generated editor.
>>> Side issue:
>>> if (uri.isFile()) {
>>> if (f.exists())
> No.
> but that is not the problem). I have no workspace concept.
So it's an RCP editor... Of course you can make assumption that you
know are valid in your application.
> was another app I inherited, then I started a complete rewrite using
> RCP, but the on-disk XML is basically the same).
> Preferences in a known place, but the actual file can be anywhere.
>>> Regards
>>> Mauro
> Thanks
> Mauro
Re: model autosave [message #656899 is a reply to message #656872] |
Mon, 28 February 2011 17:24   |
Thanks Ed,
Comments below.
Il 28/02/2011 21:28, Ed Merks ha scritto:
>>>> Hi,
>>>> event of a crash.
>> different ways:
>> DataBinding.
This may well be my problem.
I do not use at all neither edit nor editor.
I do use just the generated model.
This is because I did not find a way to have the generated editor work
as I like.
I do not want to have an RCP editor integrated in a generic eclipse
installation.
I want to build an application that edits my file, and thus the model.
I need something akin to RCP plugin.xml editor, but without all IDE
around it; just an editor for a single file type.
I think I missed something important, but I'm not really sure.
I do confirm I have no undo/redo in my editor (aside from the TextEditor
part, of course).
I am just plainly using DataBinding; e.g.:
private IObservableValue observableScene;
// Databinding
EMFDataBindingContext dbc = new EMFDataBindingContext();
IWidgetValueProperty text = WidgetProperties.text(SWT.Modify);
IWidgetValueProperty sel = WidgetProperties.selection();
dbc.bindValue(sel.observe(btnTitle),EMFProperties.value(it.c ondarelli.writer.model.world.WorldPackage.Literals.IBASE__UN USED).observeDetail(observableScene));
dbc.bindValue(text.observeDelayed(400,txtTitle),EMFPropertie s.value(it.condarelli.writer.model.world.WorldPackage.Litera ls.IBASE__TITLE).observeDetail(observableScene));
dbc.bindValue(text.observeDelayed(400,txtDesc),EMFProperties .value(it.condarelli.writer.model.world.WorldPackage.Literal s.IBASE__DESC).observeDetail(observableScene));
Am I doing something seriously wrong?
TiA
Mauro
Re: model autosave [message #656909 is a reply to message #656899] |
Mon, 28 February 2011 18:00   |
Mauro,
Comments below.
> Thanks Ed,
> Comments below.
>>>>> Hi,
>>>>> to a
>>>>> event of a crash.
>>>> result
>>> different ways:
>>> DataBinding.
> as I like.
Hmmm. Implementing undo isn't trivial.
> installation.
I'm just guessing at what you're doing...
RCP let's you build pretty much anything. Not sure how you're building
what you're doing. Just with SWT? Are you using JFace?
> TextEditor part, of course).
> // Databinding
No, it's just not what I'm expecting. Certainly you can listen to
everything like what you're doing and filter things that cause problems.
> TiA
> Mauro
Re: model autosave [message #657040 is a reply to message #656909] |
Tue, 01 March 2011 07:25   |
Il 01/03/2011 00:00, Ed Merks ha scritto:
> Mauro,
> Comments below.
>> Thanks Ed,
>> Comments below.
>>>>>> Hi,
>>>>>> to a
>>>>>> event of a crash.
>>>>> result
>>>> different ways:
>>>> DataBinding.
>> as I like.
>> installation.
This is a novel-writing program.
It helps you breaking the work into book/chapter/scene hierarchy and
keeping track of several globals like characters and places.
I have the main hierarchy in a master tree (with some virtual nodes
representing characters, places, ...) and I have a detail page to edit
each node independently.
The TextEditor (unsurprisingly!) is used to edit the actual contents of
each scene.
The accessory data helps keep consistency (who is where when?) and to
ease workflow (scene revision and rating).
This is a simplified overview just to let You know what we are speaking
about.
I am using JFace and FormTooklit.
I have three EMF models in my app: the real model, a legacy format for
import/export and a small thing used in Preferences.
>> [example deleted ...]
I currently solved my problems adding a status variable and simply
ignoring everything happening while I'm saving to temporary.
I would really like to understand how EMF is supposed to work.
I fear I'm twisting it to do things in a non-standard way and thus not
taking advantage of all available facilities (e.g.: undo/redo).
I generated (even if I do not currently use them) edit and editor and I
see they are quite complex.
I own the latest Eclipse Rich Client Platform (Second Edition), but that
doesn't cover EMF.
Where can I find relevant documentation?
My main source of inspiration has been (up to now) Tom Schindl's
EMF-Databinding series, but I seem to understand You are looking at EMF
from a different vantage point.
I am currently struggling to get a valid overview of the whole thing,
but I either find too generic things which fall apart as soon as You try
to use them in "real life" or too-specialized snippets I fail to place
in the correct framework.
Does someone know about some better info source?
TiA
Mauro
Re: model autosave [message #657084 is a reply to message #657040] |
Tue, 01 March 2011 09:57   |
Mauro,
Comments below.
>> Mauro,
>> Comments below.
>>> Thanks Ed,
>>> Comments below.
>>>>>>> Hi,
>>>>>>> to a
>>>>>>> event of a crash.
>>>>>> result
>>>>> different ways:
>>>>> DataBinding.
>>>>> being
>>> as I like.
>>> installation.
> of each scene.
> speaking about.
Certainly I would have expected you to start with the generated editor
and morph that into what you need, or pull out the pieces to reuse them...
> I see they are quite complex.
Implementing all this complexity from scratch yourself will certainly
help you understand it better than code you've never looked at it
detail, but that's a little bit like reinventing a simpler wheel.
> that doesn't cover EMF.
You've looked at EMF documentation page and noticed there's an EMF book
(Second Edition)?
> EMF from a different vantage point.
Tom's provided data binding support that makes use of EMF's command stack.
> try to use them in "real life" or too-specialized snippets I fail to
> place in the correct framework.
Not sure what you've looked at yet. There are overview papers,
tutorials, articles, podcasts, and a book.
> TiA
> Mauro
Re: model autosave [message #657277 is a reply to message #657084] |
Wed, 02 March 2011 05:21   |
Thanks Ed,
comments below.
Il 01/03/2011 15:57, Ed Merks ha scritto:
> Mauro,
> Comments below.
I didn't find a good way to do it.
It seemed just too different from what I needed.
Not enough knowledge at the time.
I will try again.
I know, but I felt like being in front of a very complex jet plan when
You really need just a bike.
I thought simpler to start from scratch than trim the boemoth down to size.
Perhaps I will know better in the next project.
> (Second Edition)?
Thanks!
I just got the book.
It will take some time to peruse through it ;)
I know that, the articles do cite it, but is unclear to me how to use
this feature. I still need to study a lot ;)
Many Thanks
Mauro
Re: model autosave [message #657388 is a reply to message #657277] |
Wed, 02 March 2011 11:19  |
Mauro,
Comments below.
> Thanks Ed,
> comments below.
>> Mauro,
>> Comments below.
>>>> problems.
>> them...
> I will try again.
It gives you a bunch of very important scaffolding and then you can
change the views it supports.
Yes, that's the usually evolution. The newbie says they want simple.
After they learn they want powerful.
> size.
What we do ourselves from scratch always seems simpler (but only to us).
>> (Second Edition)?
> Thanks!
>> stack.
Yep.
> Many Thanks
> Mauro
Current Time: Sun Jul 20 18:33:29 EDT 2025
Powered by FUDForum. Page generated in 0.17491 seconds
