Eclipse hangs when opening specific files [message #655976] |
Wed, 23 February 2011 10:37  |
Hi.
I have had this issue on Windows Vista and now on Windows 7 64bit using Eclipse 32bit (couldn't get 64bit to work).
Java 6 Update 23.
Most files are perfectly fine, but there are a few files (created by my predecessor) that hang Eclipse for anything between half a minute to 5 minutes. Eclipse becomes unresponsive, and my computer's fans speed up considerably after a bit.
I have a suspicion it has to do with the error/syntax checking feature, but I haven't quite figured out which of the many features to turn off to make the pages load faster.
I also haven't figured out yet what makes one page load normally and others not - it could simply be the amount of complexity in the page, i.e. mixing PHP, HTML and JavaScript code, sometimes using echo and sometimes closing PHP tags.
Is there anything I can do about this?
Which options/settings are the most likely to help speed up loading these pages?
Thanks!
[edit]
... oh, forgot - once such a file opens, making changes to it is also very slow - sometimes it takes 2 seconds per typed character for it to show up. That's another thing that I am hoping someone has a remedy for. My guess is that the two issues are linked and that the same solution will apply to both.
Thanks!
[Updated on: Wed, 23 February 2011 10:48] by Moderator
FUDForum. Page generated in 0.06514 seconds
