Home » Modeling » M2T (model-to-text transformation) » [Acceleo] multiples imports of classes associates([Acceleo] multiples imports of classes associates)
[Acceleo] multiples imports of classes associates [message #655708] |
Tue, 22 February 2011 06:55  |
I come back to need your help, please.
I have one class that can it have multiples associations, and I have that make the imports of the paramaters of all operations of associates classes in the first class. I have the following code:
[template private loadSeqClassAssociates(loadSeqClassAssociates : Sequence(Class), bagParameters: Bag(Parameter), isLastAssociation : Boolean, qualifiedNameClass : String) post (trim())]
[for (classPrueba : Class | loadSeqClassAssociates)]
classPrueba -> [classPrueba.name/]
[/for]
[for (classAssociated : Class | loadSeqClassAssociates)]
[let bagParams : Bag(Parameter) = bagParameters -> union(listOfAllParameters(classAssociated))]
[printImportsParametersForBusiness(bagParams, isLastAssociation, qualifiedNameClass) /]
[/let]
[/for]
[/template]
[template public printImportsParametersForBusiness(bagParams : Bag(Parameter), isLastAssociation : Boolean, qualifiedNameClass : String)]
[if (isLastAssociation)][/comment]
[let setParams : Set(String) = bagParams -> collect(type.name) -> asSet()]
[for (className : String | setParams)]
[if (isTypeBasic(className))]
//[className/]
[else]
[let c : Class = findClass(className)]
[if (c.oclIsTypeOf(Class))]
[if (not qualifiedNameClass.equalsIgnoreCase(c.qualifiedName.substrin g(1, c.qualifiedName.index('::'.concat(c.name)))))]
import gnf.[c.qualifiedName.replaceAll('::', '.')/];
[/if]
[/if]
[/let]
[/if]
[/for]
[/let]
[/if][/comment]
[/template]
[template public importsParametersForBusiness(c : Class, qualifiedNameClass : String) post (trim())]
[let seqClassAssocites : Sequence(Class) = Sequence{}]
[let bagParameters : Bag(Parameter) = Bag{}]
[let seqAssociations : Sequence(Association) = c.getAssociations() -> select(a : Association | not c.name.equalsIgnoreCase(a.endType->first().name)) -> asSequence()]
[for (a : Association | seqAssociations)]
[let numAssociationsValid : Integer = seqAssociations -> size()]
[let isLastAssociation : Boolean = seqAssociations -> last().endType -> first().name.equalsIgnoreCase(a.endType -> first().name)]
[let class : Class = findClass(a.endType->first().name)]
[loadSeqClassAssociates(seqClassAssocites -> append(class), bagParameters, isLastAssociation, qualifiedNameClass) /]
[/let][/let][/let]
[/for]
[/let][/let][/let]
[/template]
And I have teh following result:
import gnf.ada.core.exceptions.ServiceException;
classPrueba -> SupplySectorQueryService
import [path ok].GasAttributesCaudalHorarioResultBean;
//Long
//Boolean
import [path ok].SimpleSupplySectorDTO;
//String
classPrueba -> SupplySectorSearchService
import [path ok].SupplySectorListingInfoRequestBean;
import [path ok].PruebaA;
import [path ok].PruebaB;
import [path ok].SupplySectorListingInfoResultBean;
import [path ok].FlowDTO;
classPrueba -> SupplySectorUpdateService
//Long
//String
//Boolean
I was hoping that in the last iteration, in the zone "****" would have the 3 classes with the it's associated. I know the variables can not be modified after of to be defined, but, this is valid for your content?, or this is a bug?. Some advice of how to make this?.
in advance, thanks for your help
Re: [Acceleo] multiples imports of classes associates [message #656100 is a reply to message #655708] |
Thu, 24 February 2011 03:12   |
--------------070303090801000705060703
Please make your question concise : I can't figure out within what you
provided here what your problem is.
What is the result you expect, with what (simplified) part of what
model, and with what (simplified) part of the templates? And what is the
"faulty" (part of the) result you obtain?
Laurent Goubet
Obeo
On 22/02/2011 12:56, olafo987 wrote:
> Hi
> [/for]
> [/let]
> [/for]
> [/template]
> //[className/]
> [else]
> [/if]
> [/if]
> [/let]
> [/if]
> [/for]
> [/let]
> [/if][/comment]
> [/template]
> [/let][/let][/let]
> [/for]
> [/let][/let][/let]
> [/template]
> And I have teh following result: import
> //Long
> //Boolean
> //String
> //Long
> //String
> //Boolean
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070303090801000705060703--
Current Time: Sat Jul 19 18:41:41 EDT 2025
Powered by FUDForum. Page generated in 0.05820 seconds
