Home » Modeling » EMF » EcoreUtil.copy() throws Exception when copying recorded ChangeDescription
EcoreUtil.copy() throws Exception when copying recorded ChangeDescription [message #655544] Mon, 21 February 2011 12:38 Go to next message
I am currently stuck at a problem regarding the copy method of the EcoreUtil class. I have recorded a ChangeDescription and want to store the description in both directions. Therefore I tried do to the following:
ChangeDescription cd1 = recorder.endRecording();
ChangeDescription cd2 = EcoreUtil.copy(cd1);
cd2.applyAndReverse()
This works fine for many cases but suddenly I ran into a case where sometimes(!) a Nullpointer Exception is thrown.
	at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.getFeature(FeatureChangeImpl.java:286)
	at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.basicGetReferenceValue(FeatureChangeImpl.java:383)
	at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.setReferenceValue(FeatureChangeImpl.java:395)
	at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.eSet(FeatureChangeImpl.java:717)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1081)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(EcoreUtil.java:769)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(EcoreUtil.java:646)
	at org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:361)
I tried the whole day to figure out whats going on (EMF is really hard to debug) and I came to the conclusion that there is maybe a problem having objectsToAttach and a reference to it in the same ChangeDescription. Like the StateMarker Object which is referenced in line 17 (above featureName="world"). I did a lot of testing and figured out that the order, in which the EcoreUtil.Copier iterates over the elements, is important. But caused by the underlying Map, the order is not deterministic. Therefore copying of the ChangeDescription fails if the reference is copied before the StateMarker object.
The Exception is thrown because the eContainer() of the FeatureChange seems to be not set or at least eContainer().getTypedkey() is null, which is set after the object is added to the model.
<change:ChangeDescription xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:change="http://www.eclipse.org/emf/2003/Change" xmlns:de.hpi.sam.dtrp.ontologies="http://basicontology/1.0">
  <objectChanges>
    <key href="data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ontologies.barkeeper.OntologyWorld.xmi#a8916258-f492-4fa2-a2f4-55402c68e888"/>
    <value featureName="artifactPool">
      <listChanges kind="REMOVE" index="1"/>
    </value>
  </objectChanges>
  <objectChanges>
    <key href="data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ontologies.barkeeper.OntologyWorld.xmi#/"/>
    <value featureName="elements">
      <listChanges index="2" referenceValues="a3802fee-2e18-4d2e-9f7c-589e48e97f1a"/>
      <listChanges kind="REMOVE" index="4"/>
      <listChanges kind="REMOVE" index="3"/>
    </value>
  </objectChanges>
  <objectChanges key="a3802fee-2e18-4d2e-9f7c-589e48e97f1a">
    <value featureName="world">
      <referenceValue href="data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ontologies.barkeeper.OntologyWorld.xmi#/"/>
    </value>
  </objectChanges>
  <objectChanges>
    <key href="data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ontologies.barkeeper.OntologyWorld.xmi#8deb6746-abc3-45f4-b513-ba44654e1a76"/>
    <value featureName="state" set="false"/>
  </objectChanges>
  <objectsToAttach xsi:type="de.hpi.sam.dtrp.ontologies:StateMarker" id="a3802fee-2e18-4d2e-9f7c-589e48e97f1a" state="guest_getBeer_hasMoney"/>
</change:ChangeDescription>
I appreciate any kind of help and thank you in advance!
Stefan
[Updated on: Mon, 21 February 2011 16:46] by Moderator
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655592 is a reply to message #655544] Mon, 21 February 2011 15:38 Go to previous messageGo to next message
Originally posted by: c.krause.cwi.nl
Hi Stefan,
what I know is that EcoreUtil.copy() not nessesarily gives you a 100%
identical copy of your model. If you have bidirectional references to
some non-contained object, EcoreUtil.copy() will not copy that
reference, because this would change the original model.
Maybe you can check whether cd2 is really identical with cd1.
Christian
On 02/21/11 18:38, dershao@dershao.de wrote:
> Hello,
> I'm currently stuck at a problem regarding the copy method of the
> Ecoreutil class. If have recorded a ChangeDescription and want to store
> at
> org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.getFeatu re(FeatureChangeImpl.java:286)
> at
> org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.basicGet ReferenceValue(FeatureChangeImpl.java:383)
> at
> org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.setRefer enceValue(FeatureChangeImpl.java:395)
> at
> org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.eSet(Fea tureChangeImpl.java:717)
> at
> org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1081)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(Ec oreUtil.java:769)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(E coreUtil.java:646)
> at org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:361 )
> to debug) and I came to the conclusion that there is may be a problem
> out that the order in which the EcoreUtil.Copier iterates over the
> elements is important. But caused by the underlying Map the order is not
> reference is copied before the StateMarker object. The Exception is
> or at least eContainer().getTypedkey() fails which is set after the
> <objectChanges>
> <key
> href=" data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ont ologies.barkeeper.OntologyWorld.xmi#a8916258-f492-4fa2-a2f4- 55402c68e888 "/>
> </value>
> </objectChanges>
> <objectChanges>
> <key
> href=" data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ont ologies.barkeeper.OntologyWorld.xmi#/ "/>
> </value>
> </objectChanges>
> <referenceValue
> </value>
> </objectChanges>
> <objectChanges>
> <key
> href=" data/worldchange/monitoring/initialstate/de.hpi.sam.dtrp.ont ologies.barkeeper.OntologyWorld.xmi#8deb6746-abc3-45f4-b513- ba44654e1a76 "/>
> </objectChanges>
> Stefan
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655601 is a reply to message #655592] Mon, 21 February 2011 16:44 Go to previous messageGo to next message
Thank you for your quick answer! Sadly the special copying behavior seems to be not the problem. I have already read about that and checked it. The exception is thrown while cd1 is copied by the EcoreUtil.Copier. Therefore it is not possible to compare the two objects if the error appears.
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655687 is a reply to message #655601] Tue, 22 February 2011 05:06 Go to previous messageGo to next message
Which version of EMF are you using? I think this was fixed...
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655719 is a reply to message #655687] Tue, 22 February 2011 07:39 Go to previous messageGo to next message
I am using the following jars:
org.eclipse.emf.ecore_2.6.1.v20100914-1218.jar
org.eclipse.emf.ecore.change_2.5.1.v20100907-1643.jar
If you have further information like a bugreport or something similar please share this. Thank you!
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655879 is a reply to message #655719] Tue, 22 February 2011 19:48 Go to previous messageGo to next message
I think is was fixed by 315753.
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #655924 is a reply to message #655879] Wed, 23 February 2011 05:34 Go to previous messageGo to next message
if have replaced the change jar with the most current stable version (org.eclipse.emf.ecore.change_2.7.0.v20110120-0110.jar) and now it is finally working.
Thank you very much Ed - you saved my day!
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescribtion [message #658215 is a reply to message #655924] Mon, 07 March 2011 07:48 Go to previous messageGo to next message
I am also hitting the same issue when i upgraded to latest Helios with EMF version. I have version as org.eclipse.emf.ecore.change_2.5.1.v20100907-1643.jar. When i try to update only this plugin to 2.7.0 . i get dependecies missing issue. Can you please tell me what else you did to get this fixed?
Re: EcoreUtil.copy() throws Exception when copying recorded ChangeDescription [message #658227 is a reply to message #655544] Mon, 07 March 2011 08:57 Go to previous message
I did not update the whole eclipse plugin. Instead I added both jar-libs in my project as a regular dependency.
Previous Topic:[Teneo/EclipseLink]Entity class [class model.impl.BookImpl] has no primary key specified
Next Topic:EMF model file
Current Time: Sat Jul 19 18:38:20 EDT 2025
Powered by FUDForum. Page generated in 0.04539 seconds
