Workspace resources on samba share and time synchronization [message #655740] |
Tue, 22 February 2011 09:35  |
Hello!
I maintain an Eclipse based application which makes heavy use of files which are linked into the workspace from a Samba (CIFS) share. Using local workspaces with a VCS is no option.
Most of the time, everything works fine. However, I have problems when the clocks between server and client and not completely synchronized. Mostly the user will see message boxes about changed resources which are just annoying. Once, I also had a freak data loss but I'm not entirely sure it is related to this.
Anyway, while I know the problem, there is not much I can do against this. Of course I can sync client and server against the same NTP server (which I do) but the Windows XP NTP client does not guarantee precision of more than one or two seconds. That's in my experience not enough to prevent this issue.
My question is: Are there other options for me? Can I reduce the precision with which Eclipse checks the timestamps? If that is not possible, are there other options for accessing a remote file share than mounting it through the OS and then linking it into workspace?
Thanks in advance!
Florian Philipp
FUDForum. Page generated in 0.04498 seconds
