Home » Archived » M2M (model-to-model transformation) » [QVTo] Setting the parent (owner) of a new element
[QVTo] Setting the parent (owner) of a new element [message #654866] Thu, 17 February 2011 08:30 Go to next message
Let's say I'm adding a new element to an activity diagram in a UML model via a transformation. The structure might look like this:
Model (top level element) contains Activity which contains some diagram elements
When I add a new element, it is owned by the Model element but not the Activity element and the owner property is read only so I can't set it explicitly. How can I set the Activity element as the parent of the new element?
Re: [QVTo] Setting the parent (owner) of a new element [message #655043 is a reply to message #654866] Fri, 18 February 2011 02:11 Go to previous messageGo to next message
Let me be clear upfront: I don't know anything about UML Activity diagrams.
However, usually, one sets the owner (container) X of an element Y by
including Y in a feature of X. For your case, (in the mapping) for the
Activity class, I would expect the Activity class to have some containment
feature that is called something like 'elements' or 'diagramElements' orso.
If you then create a diagram element and include it in the 'elements'
feature, it would be contained (owned by) the instance of the Activity class.
Hope this helps,
Dennis
Haffi wrote:
> elements
> element?
Re: [QVTo] Setting the parent (owner) of a new element [message #655131 is a reply to message #655043] Fri, 18 February 2011 08:04 Go to previous messageGo to next message
The Activity container has a property called 'ownedElements' which is also read only like the 'owner' so I'm stumped. (The mapping itself is actually working with an element in the activity diagram but not the diagram itself, but I guess that shouldn't matter)
Via debugging I've found a property of the Activity container which is called node and is a set of the nodes, but it's hidden because if I try to do something like:
activityContainer.node := something...
the editor gives me an error that 'node' is not a variable.
Re: [QVTo] Setting the parent (owner) of a new element [message #655491 is a reply to message #655131] Mon, 21 February 2011 07:14 Go to previous messageGo to next message
Originally posted by: koen.yskout.cs.kuleuven.be
The properties you have tried to set (e.g., ownedElements) are derived
as the union of several other properties, so you can't set/modify it.
Activity does have a (non-derived) property 'node' which contains the
ActivityNodes of that activity, so it should be possible to set or
modify this. Probably, there is an error in your syntax (or in the
things that supposedly don't matter :p), so I guess you'd need to
provide more specific information to solve that particular problem.
Btw, an easy way to explore the UML metamodel is by using the Metamodel
Explorer view that ships with QVTo, to find out which properties exist
and are (or aren't) derived. To me, this is easier than using the
debugger :)
Koen
> activityContainer.node := something... the editor gives me an error that
Re: [QVTo] Setting the parent (owner) of a new element [message #655507 is a reply to message #655491] Mon, 21 February 2011 08:54 Go to previous messageGo to next message
Thank you for pointing out the metamodel explorer, it's very helpful. I still can't find a way to change or set the node property, the list of possible methods on the object doesn't seem to contain anything to influence this. Is it possible that I might somehow have to change this through Java code?
Re: [QVTo] Setting the parent (owner) of a new element [message #655669 is a reply to message #655507] Tue, 22 February 2011 04:17 Go to previous message
Haffi,
No, you should not need Java code to do this.
The following simple transformation works for me without any problems,
so I'm not sure what causes the problems you are having...
modeltype UML "strict"
uses uml("http://www.eclipse.org/uml2/3.0.0/UML");
transformation SampleTransformation(inout model : UML);
main() {
model.rootObjects()[Model]->map testAddActivity();
mapping inout UML::Model::testAddActivity() {
self.packagedElement += map newActivityWithFlowFinalNode();
mapping newActivityWithFlowFinalNode() : UML::Activity {
name := "testActivity";
node += object FlowFinalNode {
name := "flowFinal";
> through Java code?
Previous Topic:[ATL] 3rd International Workshop on Model Transformation with ATL (MtATL2011)
Next Topic:[ATL] automatic copy of a model
Current Time: Sat Jul 19 06:24:13 EDT 2025
Powered by FUDForum. Page generated in 0.05177 seconds
