Home » Modeling » GMF (Graphical Modeling Framework) » menu command not working when launched in exe . works when launched from product file
menu command not working when launched in exe . works when launched from product file [message #655060] Fri, 18 February 2011 03:32 Go to next message
i have a gmf editor which has a menu command which on pressing will generate code
the following is project hierarchy
xxxx.xxx.xxx.mist(gmf plugin)
xxx.xxx.xxx..diagram(generated code)
xxx.xxx.xxx.editor(generated code
xxx.xxx.xxx.edit(generated code)
xxx.xxx.xxx.custom(custom plugin)
xxx.xxx.xxx.generator(xpand plugin)
through extensions i add a command to mist plugin. which generates code.
i created a xxx.product file in my mist plugin and making the application point to mist diagram application(rcp generated)
If I run the plugin as a product that is by launching as a eclipse application from MistGui.product. every thing works fine.(code gets generated Very Happy)
If I run the exe of the product from generating code from menu works.(no log is generated) Sad no error is getting generated.
what can be the probable reason ? please point out
Re: menu command not working when launched in exe . works when launched from product file [message #657899 is a reply to message #655060] Fri, 04 March 2011 09:44 Go to previous message
i didn't include the src folder in the binary build of the required plug in so i was not able to get the location
it's working now
Previous Topic:A Creation Tool for every model/figure?
Next Topic:[GMF] Read-only shortcuts
Current Time: Sun Jul 20 13:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.27380 seconds
